Thread: 1995 camaro ride height
05-08-2017, 10:49 AM #1
I have a friend that is looking to raise his ride height presumably higher than stock... lots of bad angled driveways and approaches in our area.
I've been looking but haven't come up with anything. Help please, thanks1999 Z/28
M6 w/ Hurst shifter and SLP skip shift eliminator, drilled rotors, Y3F package, SLP lid w/ K&N filter, VFN fiberglass 2" cowl hood, TSP 1 3/4" headers & ORY
05-08-2017, 11:36 AM #2Spaz is My Mentor
As funny as this is there is one around my area that has done this.....
05-08-2017, 12:55 PM #3
I'm not sure I've ever heard of someone trying to raise one up, so I don't think any aftermarket companies support anything like that. If you were going to do it there would have to be some sort of coil spring spacer out back, or for the front struts. That or custom made springs that increase height. Be forewarned that the steering and suspension geometry would then be off. Driveshaft as well.
05-08-2017, 01:25 PM #4Spaz is My Mentor
Only way I can see that wouldn't radically change the above that 5.0 stated is to get larger wheels and tires. But depending on the size you may have rubbing and/or ride issues. The smaller the side wall height the stiffer the tire. Just don't put on what I call wagon wheels. I've seen ppl running with 20's and up with what looks like a rubber band for a tire.
05-08-2017, 07:04 PM #5
I didn't figure that there would be anything out there...but I did tell him that I would check around.
thanks.
What is normal ride height???
By Whamhammer in forum Suspension and HandlingReplies: 2Last Post: 05-21-2016, 02:25 PM -
Ride height question QA1r's and V6 springs
By 01WS6475hp in forum Drag RacingReplies: 2Last Post: 07-21-2008, 05:17 PM -
By Dr.Crash in forum Suspension and HandlingReplies: 3Last Post: 06-29-2008, 12:18 AM -
ride height?
By Dr.Crash in forum Suspension and HandlingReplies: 8Last Post: 09-11-2007, 11:02 AM -
Stock ride height?
By UKXK189 in forum Suspension and HandlingReplies: 1Last Post: 07-26-2007, 01:14 PM
