06-29-2016, 04:09 PM #1Junior Member
- Jun 2016
- Michigan
black- 2001 Firebird Formula
Can't put gas in nearly empty fuel tank - spills out neck
I have an 01 Pontiac Firebird Formula. When I went to put gas in it today (the tank was nearly empty), the gas immediately spilled out as if it were over filled. Any ideas as to what could cause this & how I can fix it? Any input will be greatly appreciated!!!!!
06-29-2016, 05:28 PM #2Member
- Apr 2014
Clogged fill pipe or maybe your valve at the gas cap is stuck.
06-29-2016, 06:17 PM #3
sounds like the anti spill check ball in the filler neck (tank end) is stuck. It's designed to shut off flow out of the filler neck in the event of a rollover.
06-29-2016, 06:20 PM #4Member
- Apr 2014
Did not know this, good info.
06-30-2016, 07:20 AM #5
06-30-2016, 10:24 AM #6Spaz is My Mentor
Find a long enough and narrow rod like a coat hanger stretched out that you can try to push the check ball back open. Otherwise it will mean going into the tank.
If you have to go in you can either drop the tank or do the access door panel mod (be careful when doing this). I've done both ways in getting to the tank, the trap door mod is by far my favorite.
07-01-2016, 04:18 PM #7
Thats good to know, thanks guys.
Hope is will help GM Formula 01.
07-01-2016, 04:37 PM #8Member
- Apr 2014
Trap door mod looks very interesting, but what smws6ta said, be careful.
Help: 98 TA fuel smell coming out of the fuel tank neck/cap
By JayTA98 in forum General HelpReplies: 23Last Post: 04-09-2014, 09:35 AM -
EVAP Canister/Fuel Filler Neck
By PatrizioD in forum GTOReplies: 3Last Post: 05-01-2013, 07:24 AM -
Storing Car,Gas tank full or empty?
By 02 HAWK in forum General HelpReplies: 11Last Post: 11-05-2009, 02:33 AM -
HELP: empty gas tank, but cant put any gas in tank
By 70ssrag in forum General HelpReplies: 4Last Post: 08-31-2007, 08:16 AM -
Fuel tank/ filler neck blockage?
By VictorG in forum General HelpReplies: 1Last Post: 01-13-2006, 04:32 AM
