Results 1 to 2 of 2
Thread: Fuel tank/ filler neck blockage?
01-10-2006, 11:04 PM #1Awaiting Activation
- Nov 2005
- IL
navy blue- 1999 Trams Am
So I went to fill er up and pulled the trigger and it started to piss out the drain and all over the place. I pulled out the hose and the gas was just sittin there in te filler neck. The gas wouldn't go down. I knew it wasnt full less than 2 gallons in it and only what went in the fill neck. Thought some one may have jammed something down there so i took a look. I got a flash light and a long hose and tried fishing around and i came to a stop. I pushed a little harder and push my way through as I'm geussing about 15 psi of pressure was released and forced the gas back out the filler neck and all over me. Is there a valve at the bottom of the filler neck at the tank? I dont think th is is goin to be a one time thing.
01-13-2006, 04:32 AM #299PontTAGuest
safety feature on these cars is a roll over valve in the fuel tank to prevent fuel leakage.I don't have any more info about it but a dealer would probably be the 1st ones to ask whats going on inside your tank.Have to done any doughnuts or wild driving maneuvers recently? something like that might force the valve shut.
Help: Can't put gas in nearly empty fuel tank - spills out neck
By GM Formula 01 in forum General HelpReplies: 7Last Post: 07-01-2016, 04:37 PM -
Help: 98 TA fuel smell coming out of the fuel tank neck/cap
By JayTA98 in forum General HelpReplies: 23Last Post: 04-09-2014, 09:35 AM -
EVAP Canister/Fuel Filler Neck
By PatrizioD in forum GTOReplies: 3Last Post: 05-01-2013, 07:24 AM -
Neck for the filler cap (oil)
By The Silver Goat in forum GTOReplies: 14Last Post: 04-14-2008, 10:38 AM -
gas tank filler necks
By venom98 in forum General HelpReplies: 14Last Post: 11-28-2007, 03:25 PM
