    Member PatrizioD's Avatar
    The Anus of America; RI
    Nero
    2006 gto
    EVAP Canister/Fuel Filler Neck
    Hey all, been a while. Couple of things I couldnt find using search tools, and also couldnt find online after countless hours searching. Here's the issue: My CEL has been on since oh, early 2010. I've taken it to have the code read at several places, and they all say it's P0455, which I know is a large leak from the fuel system. I cant seem to find a diagram or picture of the location of the evap canister anywhere. Do I need to remove the gas tank to access it? I've already replaced the gas cap a few times to no avail, and am also considering replacing the fuel filler neck. Are there any special tips or tricks to getting this done? Any help would be greatly appreciated.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I believe the evap canister is above the rear differential, but I could be wrong as I haven't been underneath mine in a while. The fuel tank, I believe, comes out from the trunk. Remove the trim and brace and you should be able to replace the filler neck with the tank still in the car.
    Nero
    2006 gto
    Thanks man. Jacked her up and looked around the diff and sure enough, there was the canister. You can actually see it from the driver' side rear wheel, but it's pretty nondescript and therefore easy to miss. Car hasn't been running poorly or anything, but I do suspect my gas mileage is lower than it should be; hopefully the evap service I'm gonna do will change that.
    North Jersey
    2004 GTO M6
    Keep us updated.
  1. Help: 98 TA fuel smell coming out of the fuel tank neck/cap
    By JayTA98 in forum General Help
    Last Post: 04-09-2014, 09:35 AM
  2. location of evap canister??
    By Mr.Lee in forum External Engine
    Last Post: 08-06-2009, 11:06 PM
  3. Neck for the filler cap (oil)
    By The Silver Goat in forum GTO
    Last Post: 04-14-2008, 10:38 AM
  4. Help with EVAP canister location in 99 Firebird
    By makoto42 in forum General Help
    Last Post: 07-20-2006, 01:05 PM
  5. Fuel tank/ filler neck blockage?
    By VictorG in forum General Help
    Last Post: 01-13-2006, 04:32 AM
