11-02-2009, 05:20 PM #1Junior Member
- Oct 2005
- VA
Black- 2002 Trans Am Firehawk
Storing Car,Gas tank full or empty?
Is it better to store a car with just a couple gallons of gas or completely full? Or does it really matter either way?
11-02-2009, 05:39 PM #2
store completely full, with stabil added to it. if the tank isnt full it can build up condensation......the stabil will keep the fuel from going bad and forming varnish and screwing up your lines/pump.
11-02-2009, 06:13 PM #3
+1.
11-02-2009, 09:00 PM #4Senior Member
- Jun 2008
- Rochester, NY Rochesterracing.com
- 2000 Camaro B4C
mine is always full before i put it away, and i put some fuel stabilizer in it to keep it good through the season
2000 B4C Special Service Package Z28 - Kooks 1&7/8 Stepped 2'' - TSP Torquer V.2 - FAST 92/92 - BDR 4000 Conveter - Xtreme Trans Stage II - Full UMI Suspension - Pacesetter LT's - Comp Drag Shocks - Magnaflow - Cutout - ZO6 MAF - FTP LID - Street Tuned -
11-03-2009, 09:55 AM #5
for the past 7 years ive been storing my car every winter. i always have about a 1/2 tank thinking when its spring, i will run to the gas station and top off the tank with fresh gas. never had any problems of any sort. the car has always run like a dream.
11-03-2009, 10:02 AM #6
full tank, put stabil in it and run the car for about 10 minutes after you put the stabil in
11-03-2009, 11:44 AM #7Every day is a gift-enjoy
- Nov 2005
- Missouri
Torch Red- 1999 Corvette Hardtop
+1 on storing it full. Also need to store it with a fresh oil change.
Torch Red -1999 FRC Corvette- Borla Stinger exhaust, Halltech Stinger intake
11-03-2009, 11:48 AM #8
I haven't done any of that stuff in the 10 years I've had mine. I store it as close to empty as possible and change the oil first thing in the spring. Not that my way is right because it most likely isn't. Just how I've done it.
11-03-2009, 06:56 PM #9Senior Member
- Jun 2008
- 2000 Camaro B4C
as long as she looks clean before shes tucked away, and fires up when the spring rolls around im happy
11-04-2009, 05:09 AM #10
11-05-2009, 12:59 AM #11Awaiting Activation
- Feb 2007
- onaway,MI
black- 2000 Z28
I've always stored mine with 1/4 tank or less and have had no problems. But the first thing I do in the spring is change the oil and fill up with 93 octane at least and run it hard to pass anything that's settled. Other than that, a fresh wash & coat of good wax and you should be good to go man.
11-05-2009, 03:33 AM #12Senior Member
- Nov 2006
- Indianapolis
I've never had a problem (that I know of, maybe the car covered it for me) storing a car a few months with less than quarter tank. However, the absolutely more correct way to store it is with a nearly full tank, with some Stabil added if it will be sitting more than 3-4 months.
Help: Can't put gas in nearly empty fuel tank - spills out neck
By GM Formula 01 in forum General HelpReplies: 7Last Post: 07-01-2016, 05:37 PM -
El Mirage Dry Lake Tank Testing - Tank Rodding
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 04-07-2011, 03:00 PM -
Cause It feels so empty without me!
By SLIM_DURST in forum Political / Debate ForumReplies: 14Last Post: 09-26-2008, 07:11 AM -
how full should the gas tank be at the track?
By greatwhiteZ28 in forum Drag RacingReplies: 17Last Post: 10-03-2007, 05:17 PM -
HELP: empty gas tank, but cant put any gas in tank
By 70ssrag in forum General HelpReplies: 4Last Post: 08-31-2007, 09:16 AM
