Thread: Turn Signal
09-29-2015, 06:30 AM #1Junior Member
- Oct 2009
- Red Bank, NJ
Silver- 2002 Pontiac Trans Am
Turn Signal
Hi everyone,
I have constant issues with my front turn signals. Every few months I still switch the signal and the dash light will come on, but it won't blink. Normally this means the bulb is crap and I replace it and on with my day. However, yesterday I replaced the bulb and the problem stayed. Any suggestions on troubleshooting before I replace the bulb socket in the front?
Also something to note, when this happens, the rear blinker does not work either (I have had bulb issues on both sides of the car).
Thank you
09-29-2015, 09:01 AM #2
09-29-2015, 09:43 AM #3Senior Member
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
You need to replace the socket. They have a habit of holding water because they are in the bottom of the turn signal housing and they burn out over the years. I would recommend replacing the entire housing and the bulb sockets so you don't have to do this again in a few months. If the housings are original they are probably cracked or full of moisture so its time to swap those too.
2000 Black TA M6 - LT's, ORY, UMI Short Stick, TT2's, Drilled/Slotted Rotors, Braided Lines, and Tuned by Vengeance
SCCA and Car Show Approved
06 Quad Cab HHHHemi - Sold
97 Camaro - Sold
09-29-2015, 09:48 AM #4Junior Member
- Oct 2009
- Red Bank, NJ
Ok great. Anyone have the part number for the housing? I found the sockets recommended for the sockets in another thread from auto zone
09-29-2015, 09:52 AM #5Senior Member
- May 2013
- Nashville, TN
These are the exact ones that I replaced mine with and they have been great so far.
Side Marker Corner Parking Lights Turn Signals Pair Set New for 98 02 Trans Am | eBay
One thing you will want to do is drill out the screw holes on the housings some before you try and thread the screws in to them when you are ready to install. The plastic is very hard and the factory GM screws are self tapping with some pretty deep threads so if they bite too much the head will break off. Drill the holes out so that the threads can bite a little without breaking.
09-30-2015, 06:19 AM #6Junior Member
- Oct 2009
- Red Bank, NJ
Question: turn signal keeps going out.
By dav-02ws6-m6 in forum General HelpReplies: 5Last Post: 02-02-2012, 02:19 AM -
Turn signal?
By GrapeApeTA in forum General HelpReplies: 15Last Post: 01-23-2011, 11:14 AM -
By SSMOKEshow in forum Camaro / SSReplies: 18Last Post: 06-09-2009, 03:18 PM -
Turn Signal
By Z28boy2000 in forum Stereo and ElectronicsReplies: 1Last Post: 03-30-2009, 11:36 AM -
Turn Signal PLEASE HELP
By TA2FST4U in forum General HelpReplies: 2Last Post: 06-01-2006, 07:35 PM
