    Member dav-02ws6-m6's Avatar
    Mar 2010
    VA
    2002 trans am ws6
    turn signal keeps going out.
    Just like the title says my front right signal keeps going out. The housing keep getting moistened. The last time it did that I drilled a small hole so that all the water would drained. After that I replaced the signal light and it only lasted for like a week. Is there any way to prevent the moist from accumulating.
    Indianapolis
    2000 WS6 6spd Hooker LT
    I took my whole turn signal housing out, found heat cracks along the top were the cause of the water getting in. I sealed those with some RTV, replaced the sockets (be ready to bend over if you get them from NAPA, but the quality is there), and I haven't had any more problems. You're socket is probably corroded, so find the water source, put new sockets in, and you'll be good to go. Nothing looks meaner than these TAs when driving with the amber DRLs and fog lights on!
    Mar 2010
    VA
    2002 trans am ws6
    Mobile PhotobucketI went ahead and removed the housing and you were 100 % right the housing had a crack on the top. I went to the auto parts and bought something to fix it. Thank you
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Try some leds too, they produce 1/4 the amount of heat.
    this....stopping the moisture from getting in at all is more important than getting it drained out. You can almost bet your socket is toast too.
    Indianapolis
    Quote Originally Posted by KMdef9 View Post
    I like the idea of LEDs, but I personally haven't seen them work right or look as good as the regular bulbs. They certainly use less current tho! Most of the people here that I've seen try them do not like the results.
  1. Turn signal?
    By GrapeApeTA in forum General Help
    Last Post: 01-23-2011, 11:14 AM
  2. right turn signal
    By bgon99ss in forum Stereo and Electronics
    Last Post: 04-19-2010, 08:49 AM
  3. Question: turn signal
    By SSMOKEshow in forum Camaro / SS
    Last Post: 06-09-2009, 03:18 PM
  4. Turn Signal
    By Z28boy2000 in forum Stereo and Electronics
    Last Post: 03-30-2009, 11:36 AM
  5. Turn Signal PLEASE HELP
    By TA2FST4U in forum General Help
    Last Post: 06-01-2006, 07:35 PM
