Results 1 to 19 of 19
Thread: turn signal
    Member SSMOKEshow's Avatar
    Feb 2008
    in the world
    1999 Camaro SS
    turn signal
    ya so i touch my car out and the turn signals dont work in or out of the car and it doesnt even make the clicking noise what can it be
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Either the fuse or the flasher comes to mind. I changed fuses and they kept popping. I changed my flasher yesterday and I haven't had any probs...YET.
    ls1ftw tigersport14's Avatar
    Tulsa
    98 trans am
    sockets, bulbs... idk. i always get that problem. i gave up and i have no blinkers
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Check the plugs at the base of the steering column if none of the above stuff works. Had a 94 that the high beams would not work after I had my wife take it to pepboy to have the low beams replaced and it turns out either the bastards unpluged the high beam harness at the base of the column to try and get her to buy high beams as well or the conector (that had clips on both sides) some how had fallen off. lol
    Army Dude robcas47's Avatar
    Ft. Rucker Area, Lower AL
    01 TA / 06 Duc 749D
    I just went through this with my d/s turn signal. It was the bulb, try swapping out your bulbs and hopefully that will be the end of that problem.
    Member devil6rr's Avatar
    NJ
    SOM / NBM
    2002 Pro Z28/2001 TurboTA
    Hey robcas47 what hood is that in your avatar?
    01 TA / 06 Duc 749D
    It's a stingray hood from vfn. I had the cowl and horn painted gloss black and had the front of the cowl cut open.
    Aug 2008
    LOS ANGELES
    did you check if the wires are getting power
    900hp for 08 PhillyLs1's Avatar
    Philly/MD
    Sebring Silver
    00 Camaro SS/09 LS3 Vette
    Quote Originally Posted by SSMOKEshow View Post
    I've heard that poor punctuation and grammar is usually the culprit.
    Feb 2008
    in the world
    1999 Camaro SS
    thanx i try
    SS-EIAN SSNAKEATER23's Avatar
    CHICAGO
    SILVER
    1999 CAMARO SS
    Try the nomal tests.....
    1. Bulbs
    2. Fuses
    3. Wires and Harness
    4. Flasher
    It sounds like a flasher issue, I had an issue w that in my monte carlo. With no clicking at all. Changed the flasher and it was all good.
    Member 6sw00's Avatar
    N.Y
    2000 trans am ws6
    my signals just struggle to blink. its strange, im guessing its the flasher but i have no clue where it is..
    Member FullBlack4thGen's Avatar
    Mar 2009
    Longisland
    98 Z28
    Make sure you change the turning light bulbs and not the daytime running bulbs.
    Big bulb = Right
    Little bulb = Not Right
    Nov 2008
    harrisburg pa.
    02 vette vert
    Quote Originally Posted by FullBlack4thGen View Post
    Big bulb = Right
    big bulb= turn signal, parking, drl. dual filament bulb.
    little bulb= side marker light. single filament bulb.
    Berkeley, CA
    2000 Camaro SS #3574 A4
    It's your bulbs. Check to see which one wont light up as a running light. Change the bulb. problem solved. I had to do it. Easiest way to get access is to remove the headlight and go in from the top, or you can unbolt some stuff on the bottom and reach up and do it.
    Berkeley, CA
    Big bulb = Right
    When it happened to me my running light didn't light up until I swapped out my blinker bulb.
    Nov 2008
    harrisburg pa.
    02 vette vert
    your running light is your blinker bulb.
    Berkeley, CA
    Quote Originally Posted by dklowrider View Post
    That's what I thought. It looked like you guys were saying there were two different sized bulbs. I only saw one. Getting me all confused.
    Nov 2008
    harrisburg pa.
    02 vette vert
    in your housing you have a 3157 for park, turn and drl, you also have a 194 bulb [small one to the side of the housing] which is your side marker light when you turn on the lights, goes along with the one on the side in the rear, except rear is red. two bulbs.
  1. Question: turn signal keeps going out.
    By dav-02ws6-m6 in forum General Help
    Last Post: 02-02-2012, 02:19 AM
  2. Turn signal?
    By GrapeApeTA in forum General Help
    Last Post: 01-23-2011, 11:14 AM
  3. right turn signal
    By bgon99ss in forum Stereo and Electronics
    Last Post: 04-19-2010, 08:49 AM
  4. Turn Signal
    By Z28boy2000 in forum Stereo and Electronics
    Last Post: 03-30-2009, 11:36 AM
  5. Turn Signal PLEASE HELP
    By TA2FST4U in forum General Help
    Last Post: 06-01-2006, 07:35 PM
