Results 1 to 3 of 3
    TA2FST4U TA2FST4U's Avatar
    Lancaster County, PA
    1999 Pontiac Trans Am WS6
    Turn Signal PLEASE HELP
    Hey, i have a 99 Trans Am ws6 and just recently my turn signals stopped flashing. Both bulbs work fine so i have come to the conclusion that it is my flasher. I was reading my manual and i went under the dash to find the flasher and i cant seem to locate it. Can someone PLEASE describe to me whereabouts the flasher is located.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    i thinks it's under the dash behind the console. you should be able to access it from the driver's side.
    Burlington, NC
    The turn signal flasher is located under the dash on the right side of the steering column along with the four way flasher. One way to determine which flasher is which is to turn on the fourways (because you said that the turn signal flasher does not work) and feel the click of the flasher. The one that you feel clicking with the four ways flashing is the four way flasher. So the other one will be your turn signal flasher. Due to the under dash cover panel, the flashers are a bit difficult to get to, but with a bit of nip and tuck you can get your hand in there between the panel and the firewall.
    JEB
  1. Question: turn signal keeps going out.
    By dav-02ws6-m6 in forum General Help
    Last Post: 02-02-2012, 02:19 AM
  2. Turn signal?
    By GrapeApeTA in forum General Help
    Last Post: 01-23-2011, 11:14 AM
  3. right turn signal
    By bgon99ss in forum Stereo and Electronics
    Last Post: 04-19-2010, 08:49 AM
  4. Question: turn signal
    By SSMOKEshow in forum Camaro / SS
    Last Post: 06-09-2009, 03:18 PM
  5. Turn Signal
    By Z28boy2000 in forum Stereo and Electronics
    Last Post: 03-30-2009, 11:36 AM
