Thread: help with noise
    Feb 2008
    jupiter fl.
    2000 trans am
    help with noise
    sounds like bad u joints but there new clunk noise when going from park to drive not bad when going from park to reverse, theres to much slack in the drive shaft. maybe the diff or the train whata think
    Orlando, FL
    Mean Black
    if you get underneath the car safely of course, grab the driveshaft. Do twisting motion and see if there is play. Look at the u joint while you do it. If you have play the u joint are bad.
    Check your transmission mount. They tend to go bad too.
    what he said....most likely u-joints but tranny mount my be worth a look too.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Not my joint, U-joint ?
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    help with noise
    Inspect the torque arm as well while you're under there. Better to check EVERYTHING under your car to be safe.
    Agree. Sounds like u-joints but, as already posted, be sure to take a look at everything while you are under the car. If nothing appears or feels amiss in the driveline, then the trans mount and torque arm mount are your next most likely culprits. After that, you'll want to look at the suspension bushings on the LCA's.
    Feb 2008
    jupiter fl.
    2000 trans am
    car has new u joints,motor an train mounts,torque arm busing,theres play in drive shaft u think the diff needs shimming I have to remove drive shaft an see if the play is in the train or diff. anyone know the specs on rearend diff play
    You measure that with the cover removed and a dial indicator. I think mine had around .011" of lash which is a bit loose.
    Feb 2008
    jupiter fl.
    2000 trans am
    thanks for the photo ,do you know what the specs are for the back lash and how do you fix it if to loose
  1. LS1 noise?
    By rafael707 in forum General Help
    Last Post: 06-28-2012, 07:58 PM
  2. noise
    By texas twister in forum Automatic Transmission
    Last Post: 03-21-2009, 04:44 PM
  3. '01 M6 Noise
    By T/Aboo in forum Manual Transmission
    Last Post: 10-09-2007, 04:49 AM
  4. Noise that I can't get rid of!!!!
    By SilentStriker07 in forum Suspension and Handling
    Last Post: 02-14-2007, 07:58 AM
  5. Bad Noise.
    By csess in forum Firebird / WS6
    Last Post: 02-11-2007, 05:30 PM
