    Sep 2011
    England
    Bubbling sail panel
    My sail panel hasn't started to bubble just yet, but I have noticed in certain light that you can see the outline of the adhesive underneath. I'm going to try and source one from a scrap yard, can anyone tell me if the sail panel from all 4th gen f-bodies (Firebird and Camaro) '93 to '02 is a universal fit?
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    I don't know the exact answer to that, however from 98-02 would be a safe bet.
    SteveC
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    I believe Steve is correct. 98-02 are the same part but prior to 98 is just a guess.
    Member pv-camaro's Avatar
    Dec 2008
    Netherlands (europe)
    Light Pewter (11)
    2001 Camaro
    i took a sail panel of a 1995 Firebird, and they are the same from 1993 - 2002, i didn't replace my sailpanel yet, but when i heard of this problem (and new they are discontinued), i drove to a junkyard, and got me one, so i can fix this if it's nessesary in the future.
    if you get one from a 1998 -2002, you will have the same problem again, cause they used the wrong glue from 1998 -2002.
    The complete roof:
    Cutting wire:
    The panel is removed:
    The metal you have to bent, for easy acces with cutting wire.
    The underside of the good panel,
    Only i have to remove the rest of the adhesive:
    pv-camaro - you are wrong on the 98's. The glue problem only effects 99< yrs.
    OP - Besides junk yards you have another option.
    6Liter Designs is the only place I know that makes replacement sail panels. (Aint't cheap, $500)
    1993-2002 Sail Roof Panel for T-Top FIBERGLASS, 6LE Designs LLC
    Orlando, FL
    Mean Black
    agreed. the wrong adhesive was from 99-02. Let us know how the panel works out for you.
    Sep 2011
    England
    Quote Originally Posted by pv-camaro View Post
    I took a sail panel of a 1995 Firebird, and they are the same from 1993 - 2002
    That is very encouraging
    Thanks for the link, and you're right $500 plus shipping to the UK is on the expensive side, but it's a back up plan at least.
    Dec 2008
    Light Pewter (11)
    2001 Camaro
    yes, you are right it only effects the 1999 til 2002
    The other option is a 6LE replacement roof, but i have no idea if they fit perfectly
    But for me, the biggest problem was, shipping such a huge panel to Europe (a lot of shippingcosts and taxes) and the panel is very fragil).
    Shipping such a panel to Europe is almost 400 dollar (oversized package), and taxes in Europe is calculated over the total cost (500 dollar for the panel and 400 dollar shipping),
    so this wasn't an option for me
    SS Camaro UK: if you search on LS1tech.com and Camaroz28.com, you can read i am not the only one took a panel from a donor car, it is by far the sheapest solution (for sure if you live outside USA), and the car stays "original".
    If you use a correct a cutting wire for removing windows, and i preheated the underside of the steel roof (see pictures) with a paintstripper, so the glue gets soft.
    I took the panel off the roof in 20 minutes, and about 15 minutes to remove the glue with a shap knife
    Member speedyWS6's Avatar
    Sep 2009
    U.K.
    2002 WS6 TA
    Hi Guys,
    Mike's original query about TA's and Camaros both having the same sail panel....
    .....It wasn't specifically answered as the posts went to the years which were
    problem free rather that TA/Camaro fitment!
    So.... is the sail panel exactly the same on '93-'02 cars or is the TA different
    to a Camaro?
    Although the WS6 i have just imported is really a peach of a car with no door cracks,
    no dash cracks, no headlight or window issues it DOES have some bubbling and
    sometime down the line it will need to get addressed!
    Thanks guys
  1. Replacing bubbling rooftop panel
    By pv-camaro in forum Appearance Section
    Last Post: 10-15-2011, 06:33 AM
  2. Question: Sail panel? the small panel right behind the window
    By Pony_Eater in forum Appearance Section
    Last Post: 07-27-2011, 07:51 PM
  3. Service Bulletin: Bubbling Sail Panels
    By Sassy Cassie in forum Appearance Section
    Last Post: 10-09-2009, 06:01 PM
  4. For Sale: Brand New Sail Panel (Roof Panel).
    By cheetoh in forum Cowhands, Local Parts and Fish Bait
    Last Post: 04-06-2009, 11:46 AM
  5. Sail panel roof bubbling.
    By TA421 in forum General Help
    Last Post: 03-30-2008, 07:33 AM
