Page 1 of 9 12345 ... LastLast
Results 1 to 20 of 166
    Mar 2003
    Melbourne, FL
    Arrow Service Bulletin: Bubbling Sail Panels
    The sail panel (on t-top cars) or the entire roof (on hardtops) of 1998 to 2002 Fbody cars may have a factory defect. If you park your car out in the sun, little bubbles about the size of a pinhead start appearing on the roof. This problem is caused by the glue used to hold the plastic roof on. The glue degasses and the gas travels up through the panel. Eventually it leaves these nice little bubbles in your paint.
    http://ls1tech.com/forums/attachment...chmentid=30522
    Member screamin chicken's Avatar
    sc
    Black, Red, Silver Jade
    00 WS6,95 Ta, 69 R code
    GM would not do a thing for me....went through the BBB and GM no help.So I have a 2000 WS6 with 32,xxx miles and it looks like crap...
    2007 Yukon XL (sold)
    2014 Z71 LTZ 3LZ (sold)
    2010 Escalade Platinum AWD , 6.2
    2017 Silverado HC , 4x4, 6.2
    2000 WS6 ASC#2300 Holly LS6 intake, TR Custom grind cam, Mac Mids w/ ORY,Hotchkis LCA's, PHB, BMR Extreme STB, BMR re-location brackets,Eibach Sportlines, GMMG, Mccleod Pro 5.0, SLP SFC's, OEM ZO6 wheels
    1995 TA
    1969 R code Mach I my new project
    Mar 2003
    Melbourne, FL
    Try another dealship. A few people have had some success getting their cars repainted.
    Marylandistan
    2001 Trans Am (sold)
    Got mine fixed out of warranty. Went through a 800# in the owners manual and a woman there got it fixed for me thru the 6 year corrosion warranty. Dealerships would not help initialy. For those wondering this costs about $700-$900 to do out your own pocket.
    Senior Member
    Jacksonville, FL
    Yeah, try another dealership. I know a couple people that had theirs done.
    Senior Member Zboner's Avatar
    cincinnati/northern ky
    99 SS
    so is it going to be recalled or what?
    99 SS
    cause mine is bubbling up
    Crinkle, Crinkle
    Warren, MI
    Nice post, Cassie, thanks!
    I was wondering what those little bubbles on my HT were.
    Anyone got that 800 number?
    --07T--
    GM Technician BLLDOGG's Avatar
    Yukon, OK
    2000 Camaro
    Please. i need that number. my car is in the body shop about to be painted cause of this with my own money.
    Heavy Set Thin Guy t/as&dds's Avatar
    MA
    Quicksilver Metallic
    2005 Pontiac GTO
    I didn't think there was a 6 year corrosion on these cars? My front bumper has been bubbling and peeling since I bought it but I was told that since it was an 01 that there was nothing I could do about it.
    HOUDINI'S RIDE
    GA
    BLUE
    Z28/SS
    hey guys the number is 1-800-762-2737 be prepared to give some info too or so im told i've been meaing ot give them a call mines bubbling up on my garaged car go figure huh 13,000 miles and my sails bubbling up !
    wow..shitty. i'll have to check mine
    Last of the Breed Pewter02Formula's Avatar
    Columbus, OH
    Pewter Metallic
    2002 Firebird Formula
    Saw this thread and immediately ran out to check my car... thankfully there's no bubbling! (Car is now 4 years old and is only garaged in winter)
    HOUDINI'S RIDE
    GA
    BLUE
    Z28/SS
    consider yourself lucky! there seems to be a large response to this problem almost seems to make you think gm would have realeased a letter to fellow f-body owners about this problem huh??
    Mechanicsburg, PA
    2001 SS Camaro
    Quote Originally Posted by 4U2ENVY View Post
    consider yourself lucky! there seems to be a large response to this problem almost seems to make you think gm would have released a letter to fellow f-body owners about this problem huh??
    X2, I'm waiting now for over a week to hear back from the dealership I took my car to to have them look at the sail panel behind the t-tops. The guy from the body shop just gave me a dumb look about my complaint until I handed him a copy of the tsb. He said he would research it, I then said to him I couldn't believe that he never had a car in the dealership with the same issue. Funny statement from him to me, "your car is a 2001 and is no longer in the 3/36k warranty and is not likely going to be covered". Me to him, "Well then why would a tsb be issued in 2003 to cover 1999 model year camaros that were bought as early as fall of 1998? My thought is those cars are out of warranty before any tsb came out and are to be included in the described fix". Another dumb look and another I'll look into it. Oh well, I'm not holding my breath.
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    Interesting...I've got what appears to be tiny bubbles in mine exactly as described.
    Camaro SS 2001
    After reeding this post, I went to see my car and...shit ! here they are. I am living in Canada and my car is a garage queen. It is rarely exposed to hot temperature and never stay long under the sun. It is definitely the last GM I will buy. I used to like GM cars but wow, this problem is too much. Damn !
    Junior Member black's Avatar
    I've got them in my hardtop as wheel
    Junior Member Jeremiah's Avatar
    Jun 2006
    Mustang Ok.
    98 Mecham TA #4 of 14
    Like someone else allready stated it is covered under corosion, its covered for six years from the original purchase date. Both my 01 SS and my 30th TA were covered by a local dealer with no problem. Also, the service bulletin is not a warrenty bulletin. It is only a refference tool for the tech to get the suggested repair/replacement procedure. GM used windsheild urithane "same adhesive used on the front/rear glass" to adhere the roof panel. The older urithane used a sepperate primer/adhesion promoter and the newer has it mixed into it allready. Other than that GM uses the same panel and the same windsheild urithane to adhere it to the roof structure. Unless the primer was causing the problem then we will be seeing the same problem on the same cars again. the roof is made from SMC (sheet moulding compound) the same composite used with the SS and WS6 hoods, doors and rear hatch. The current replacement roofs are exactly the same as your originals. SMC has the same expansion rate as steel and is more durable than Fiberglass of the same thickness, GM no longer uses fiberglass on any thing. I am a body tech and I used to work for a Chevy dealer and have done several of the replacements.
    __________________
    Rogersville,Tn
    2001 Trans Am
    Just washed my car today and found three bubbles behind the t-tops. Nice post I appreciate the info. 01 WS6 53,xxx really shows up on a black car.
  1. Bubbling sail panel
    By SS Camaro UK in forum General Help
    Last Post: 11-01-2013, 01:40 AM
  2. Help: Tecnical service bulletin on hatch release ?
    By mdcrabbie in forum Camaro / SS
    Last Post: 02-25-2009, 05:33 PM
  3. Ebony door panels,headlights,sail panels
    By VENOMOUS in forum Parts For Sale / Trade
    Last Post: 02-02-2009, 07:30 AM
  4. Sail panel roof bubbling.
    By TA421 in forum General Help
    Last Post: 03-30-2008, 07:33 AM
  5. Tech Service Bulletin?
    By grandkodiak in forum LT1
    Last Post: 02-01-2007, 07:07 PM
