07-09-2011, 09:36 PM #1
Sail panel? the small panel right behind the window
Can you replace these? I remember seeing a sticker overlay somewhere but cant seem to find it anymore anyone know? Its the panel that looks like a triangle right behind the window.
07-10-2011, 01:58 PM #2
07-11-2011, 07:31 AM #3
you can replace them. they have a strong double side tape on them. I was able to pull one out of a junk yard but it was a pain and if you are not careful you will ruin it. If you can find one then you can just pry it out carefully. The base were is attach to is part of the big sail panel.
07-12-2011, 09:11 AM #4Junior Member
- Sep 2009
- vallejo (bay area), ca
red- '98 TRANS AM
if you slip a small flathead (like 1/8" wide) in at the bottom/side nearest the window its fairly easy to start there when beginning to pry it off. Just be very careful, from what i remember, it seemed pretty flimsy, probably easy to bend/break. good luck
as for a cover, emblempros.com carries some: http://emblempros.com/other_exterior?b=1 and you should be able to find them on ebay
07-27-2011, 07:51 PM #5
We make a stainless or acrylic decorative peice you can place there.
http://emblempros.com/other_exterior2?b=1
Thanks, Roger
Question: Sail panel fix
By MudStainKILLA in forum Appearance SectionReplies: 11Last Post: 06-28-2012, 02:28 PM -
Question: New Sail Panel
By 02fbody35th in forum Appearance SectionReplies: 9Last Post: 04-02-2011, 10:59 AM -
Wanted: New or Used Roof Panel (Sail Panel)
By dixielegger1 in forum Parts Wanted / TradeReplies: 2Last Post: 04-09-2009, 06:12 AM -
For Sale: Brand New Sail Panel (Roof Panel).
By cheetoh in forum Cowhands, Local Parts and Fish BaitReplies: 3Last Post: 04-06-2009, 11:46 AM -
10's in sail panel?
By Racquetballryan in forum Stereo and ElectronicsReplies: 4Last Post: 11-28-2006, 08:18 PM
