View Poll Results: Plain or Carbon Fiber Sail Panel?
- Voters
- 15. You may not vote on this poll
Thread: Sail panel fix
06-12-2012, 05:59 AM #1
Sail panel fix
Gonna be back in cali soon and starting on the body work that the bird needs, one problem being my sail panel yay..... Going to pick up a new panel from 6LE but was wondering what glue i should use so that I don't run into the same problem I ran into before with the bleed through from the factory. Also if any one has pics of the CF sail panel installed I'd love to see it. Thanks in advance guys.
2002 Trans Am WS.6 A-4:
Volant CAI, BBK LTs, BBK ORY, SLP LM2, FROST Tune, A/C Heat Delete, AIR Delete
06-17-2012, 03:59 AM #2Your friendly policeman
- Jan 2012
- Alabama
Bright Rally Red- 2001 Chevy Camaro Z28
I believe regular urethane will do the trick just fine. Obviously, that's not what GM used.
2001 Chevy Camaro Z28 A4
SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
06-17-2012, 06:27 AM #3
thanks for the info man
06-19-2012, 06:31 AM #4
I'm a CF fan, also if you don't want the CF look you can always prep and paint it too.
06-19-2012, 02:33 PM #5
06-24-2012, 02:36 PM #6
The piece you will receive will be exactly what you would have received from GM, a FULL REPLACEMENT PANEL. Ours will be a flexlible fiberglass and will have the finish of our other flexible fiberglass parts.) All you need to do is rip off your old one (have fun tearing that beast apart and DESTROY it as retaliation for the pain it is putting you through! In other words, you can use a pry bar, putty knife, whatever you want HOWEVER piano wire or wire saw might be the cleanest and easiest way to remove it), remove any old caulk/glue/adhesive from the metal underneath, apply caulk/adhesive (we recommend Pro Grip, U400 HV Essex (Dow) or 3M Urethane 08690) and stick it on (follow instructions on the adhesive, you might need to clamp the roof on for a drying period)!
This should help. It's straight from their site.2002 Artic White SS 35th Wheels|Full Hotchkis Suspension|Koni SA|Magnaflow CME|SLP lid|www.fquick.com/The_Guz
06-24-2012, 03:28 PM #7Former Mopar Man
- Jun 2011
- Branchville, NJ
06-24-2012, 03:47 PM #8Senior Member
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
Saw one of the CF ones on a pewter TA at a car show the other week and it looked pretty cool
06-27-2012, 12:18 PM #9Join the PHK @ thephk.org
- Nov 2007
- Studio City, CA
Red- 2001 Camaro SS
I've got a few pics of the carbon fiber one a friend installed from the write up he did. Let me look around and find them....
Join the PHK2009 LS1.com Calendar Car
06-27-2012, 12:28 PM #10Join the PHK @ thephk.org
- Nov 2007
- Studio City, CA
Red- 2001 Camaro SS
Found 'em!.... But these are of a carbon fiber Targa top and sail panel.
06-27-2012, 08:45 PM #11
with your car being black it i think it would look good and if not just paint it. all the ricers kind of killed the cf thing for me but that pic it looks cool
06-28-2012, 02:28 PM #12
thanks for the pics! ya the ricers def did kill it, but those pics it does look nice
Question: Sail panel? the small panel right behind the window
By Pony_Eater in forum Appearance SectionReplies: 4Last Post: 07-27-2011, 07:51 PM -
Question: New Sail Panel
By 02fbody35th in forum Appearance SectionReplies: 9Last Post: 04-02-2011, 10:59 AM -
Help: sail panel fix
By MudStainKILLA in forum Appearance SectionReplies: 4Last Post: 02-14-2011, 03:19 AM -
Wanted: New or Used Roof Panel (Sail Panel)
By dixielegger1 in forum Parts Wanted / TradeReplies: 2Last Post: 04-09-2009, 06:12 AM -
For Sale: Brand New Sail Panel (Roof Panel).
By cheetoh in forum Cowhands, Local Parts and Fish BaitReplies: 3Last Post: 04-06-2009, 11:46 AM
