    May 2012
    Ohio
    2002 Z28 Camaro
    Oil pressure question on 2002 Z-28 Camaro
    Hi Everybody,
    Just got a 2002 Z28 Camaro. Did a mobil 1 full synthetic 10w-30 oil change, with K&N air and oil fitler. Then I put in valvoline complete fuel system cleaner and filled up with shell v-power 93 gas. Now my oil pressure needles stays between 45-80 psi, but when I turn the car off, the needle doesn't go down and stays on the 45 psi level. Any ideas what might cause this?
    Thanks
    -MATT-
    Coral Springs, Fl
    Sunset Orange Metalic
    After a while does it go down?
    Your friendly policeman FinZ28's Avatar
    Jan 2012
    Alabama
    Bright Rally Red
    2001 Chevy Camaro Z28
    General rule of thumb regarding oil pressure is 10psi for every 1000 rpm. The oil pressure gauge in the '99-'02 F-bodies is not a mechanical gauge, so the reading isn't exact. My car usually stays around 40psi at idle until it warms up, then drops to around 30psi after it has been driven a bit (at idle, that is). As for your gauge not going back to 0 when you shut the car off, I believe that's normal, as mine does it, also. If you shut the engine off then turn the key on, it should drop back to 0. So long as your gauge moves when you increase your engine rpm's, you're okay (unless the reading is very low).
    2001 Chevy Camaro Z28 A4
    SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
    May 2012
    Ohio
    2002 Z28 Camaro
    Not sure. I know after an hour id didn't.
    I know it never goes down under 40psi, even when I'm driving. So I hope it is ok.
    Thanks again guys for the replies.
    -MATT-
    Indianapolis
    2000 WS6 6spd Hooker LT
    What does it read with Key On Engine Off (KOEO)?
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Quote Originally Posted by Camaro352002z28 View Post
    -MATT-
    My 02 SS stays above 40 psi all the time. I run 80 psi when cold at 2000 rpm and then when it get warm I drop to 65 - 70 psi at 2k and 45 psi in traffic at idle and hot. I do not think the GM oil pressure gauge is very accurate so just make sure the oil is full, clean and no unusual noises coming from the engine. The OPSU may also be an issue.
    May 2012
    Ohio
    2002 Z28 Camaro
    The needle goes down to 0 when I do that, then back up to 40 psi or higher when I start the engine and driving.
    Someone told me the oil sending unit, do you think the change to synthetic oil would have something to do with it?
    Thanks
    -MATT-
    Jun 2011
    Branchville, NJ
    Silver & Blue
    Thanks
    -MATT-
    I would start by changing the OPSU first. Not an easy job, you may need to pull the intake to get at it.
    Indianapolis
    Thanks
    -MATT-
    Sounds like perfectly normal oil gauge functioning, and oil pressure readings.
    The gauges are not active with the ignition off, only when it is on. These are not purely mechanical gauges, maybe that's whay you're used to?
    My oil pressure reads about 35-40 when at hot idle, and goes up to 65-70 at higher RPM when hot, and I've always used 5W30 synthetic oils.
    Any reason why you are using 10W30? Hot summer months maybe? Even then, stock GM for the LS1 is 5W30. But if you wanted a heavier
    weight oil, you should be using a 10w40, since that would be thicker at higher temps.
  1. Oil Pressure Question
    By BradZ01 in forum General Help
    Last Post: 10-01-2009, 09:48 PM
  2. Help: 2002 SS camaro question===Tires
    By Footlead in forum Wheels and Tires
    Last Post: 04-01-2008, 05:58 PM
  3. SLP Question 2002 SS Camaro
    By firehawk71 in forum Camaro / SS
    Last Post: 12-31-2007, 06:55 AM
  4. oil pressure question
    By b.lee in forum General Help
    Last Post: 09-29-2007, 09:56 PM
  5. oil pressure question
    By gsxrsteve in forum General Help
    Last Post: 07-14-2007, 11:54 PM
