Results 1 to 20 of 76
Thread: oil pressure question
07-07-2007, 09:22 AM #1
I went to look at a 98 trans am ls1 auto 96k miles today
It was warm and when idling only had 20 psi oil pressure on the gauge. (stock of course)
It got a 40 psi pretty easily.
I didnt really get on it either.
He said he was running some synthetic oil in it also.
Do those sound like decent readings?
Would thin oil cause this?00 Z28 M6 T-tops
00 SS A4 T-tops (Sold)
99 Corvette M6 (Sold)
98 Z28 A4 Coupe (Sold)
98 Z28 A4 T-tops (Sold)
07-07-2007, 11:18 AM #2
If you get on the throttle a little, it will go over 40 psi.
It has 40 psi normal driving.
Let off the gas completely and it drops to 20 psi.
normal? common problem? thin oil?
oil is not low, and its nice and clean.
07-07-2007, 06:25 PM #3
my 00 ta idles at around 40 psi and under normal driving conditions about 60,im not sure why yours is lower id get oil pump checked out,i run mobil 1 synthetic 10 w 30 but gonna switch to lucas full synthetic
07-07-2007, 06:57 PM #4
my 98 is at 20 at idle. It is a prob. Either the oil pump is shot or the o ring is giving. 20 psi is too low for our cars to be honest. You should be seeing around 40 psi
07-07-2007, 07:25 PM #5LoudMouth
- Jul 2006
- Westminster/Sykesville, Maryland
Red- 2000 Trans Am
Mine gets pretty low but according to the book its safe. I think alot of it has to do with the gauges. They probly dont read that well.
07-07-2007, 07:29 PM #6
07-08-2007, 07:33 AM #7Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
07-08-2007, 08:24 AM #8King 0f n00bz
- Jan 2006
- Shepherd, Michigan
usually when you are that low it means the oil pump is going. my 98 47k runs 40-50 all the time.
07-08-2007, 09:06 AM #9
07-08-2007, 09:41 AM #10
I always thought mine ran a lil high. 50-70. When it is cold it will creep past 70. I always let my car run til the temp gauge starts moving up before I drive it, but when it is still cool and I am going through the gears...it creeps past 70. When It is completely warmed up, at 60 mph on cruis control the psi is just under 60. Mine is 2002 WS6, M6, stock, 93 octane. If y'all wouldn't mind...try cruisin at 60 mph after the engine is warmed up, and post your psi...I'm just curious
07-08-2007, 10:05 AM #11
07-08-2007, 10:12 AM #12
07-08-2007, 11:05 AM #13Junior Member
- Jun 2007
- Somers, NY
Black- 2002 Pontiac Firehawk
07-08-2007, 03:26 PM #14
my 2000 with 500 on it idles a lil about 40 and will hit past 60 with no prob when i get on it but 20 does seem just way to low
07-09-2007, 08:43 AM #15
? is it bad if when engine is cold my oil pressure is around 76psi. it worries the crap out of me but when in normal temperature it reads between 40-50psi
07-09-2007, 09:00 AM #16Impounded
- Mar 2007
- Milwaukee
Red- 2000 Trans Am
slightly over 40 when warm and idle
07-09-2007, 09:09 AM #17
07-09-2007, 11:03 AM #18
I dont want to buy a car to fix it, thats for sure.
On another note, I've always heard since i was 14 to never use pennzoil oil.
No matter what kind it is.
Its dirty, nasty, and basically the worst oil on the planet.
I'd use valvoline, quaker state, walmart brand, before I used pennzoil.
*back on topic
Is there any way to tell if the sending unit or the oil pump is bad?
Or any way to tell if its an engine problem?
07-09-2007, 02:06 PM #19
07-09-2007, 02:11 PM #2098T/AformulaGuest
Oil temp/pressure question.
By Young11b in forum Internal EngineReplies: 11Last Post: 08-29-2012, 12:13 AM -
Oil Pressure Question
By BradZ01 in forum General HelpReplies: 1Last Post: 10-01-2009, 09:48 PM -
By VENOMIZED03 in forum Internal EngineReplies: 11Last Post: 01-25-2008, 11:05 PM -
By gsxrsteve in forum General HelpReplies: 1Last Post: 07-14-2007, 11:54 PM -
By gsxrsteve in forum General HelpReplies: 2Last Post: 07-13-2007, 04:44 AM
