Results 1 to 2 of 2
    ne kansas
    01 Z28
    oil pressure question
    01 z m6 when im at idle i have around 45 psi oil when im at red line the oil pressure gets dam near 80 psi want to know if anyone else has this going on i run castrol syntec 5 30 i tried other kinds and weights to see if that was it just curious on if its normal or something getting ready to puke car has 109k on it also
    Bragg NC
    Met. Sunset Orange
    01 SS
    The pump is driven off of your crank so as your crank spins faster, so does the pump.
    Iv never seen it that high but i wouldnt be to concerned with it. The bright side is if you do break something that just leaves room for bigger and better things.... lol, you should be fine thou
    J
  1. Oil temp/pressure question.
    By Young11b in forum Internal Engine
    Last Post: 08-29-2012, 12:13 AM
  2. Oil Pressure Question
    By BradZ01 in forum General Help
    Last Post: 10-01-2009, 09:48 PM
  3. Oil Pressure Question
    By VENOMIZED03 in forum Internal Engine
    Last Post: 01-25-2008, 11:05 PM
  4. oil pressure question
    By b.lee in forum General Help
    Last Post: 09-29-2007, 09:56 PM
  5. oil pressure question
    By gsxrsteve in forum General Help
    Last Post: 07-13-2007, 04:44 AM
