Results 1 to 10 of 10
    Apr 2012
    woodbury
    maroon
    94 camaro
    Need help lt1 wont start
    I have a 94 camaro z28 that came factory with an LT1 and tranny. I bought the car with no motor no tranny. I have a motor and tranny out of a 95 z28. the motor is put in and everything i believe is to be hooked up. I went to start it and heard a clicking noise. Come to find out I had three wires hooked up to the starter instead of two. I heard one of the wires, I believe the black one, was the ground to oil pan. Still just clicking only a little louder. I am going to take the starter to get checked in a bit. But is there anything else I should check just in case???? Thanks in advance
    is the motor grounded to the car body?
    Also Opti-spark = constant ignition problems
    Apr 2012
    woodbury
    maroon
    94 camaro
    Are you talking about the battery ground? I have it grounded to the motor mount. I dont know if this is correct this is my first fourth gen. and it seems like i am running into probs everywhere lol. there is also a ground on the driver side that i just spotted and its not hooked to anything any clue where this goes.?
    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    are the dash lights doing weird things? if so, your computer may not be recieving proper ground....i had that problem with my engine swap
    EDIT: actually, my engine did turn over, just wasnt getting spark or fuel.
    Apr 2012
    woodbury
    maroon
    94 camaro
    the dash lights are on and even the door bell ringers ding. i was guessing the reason the dash lights havent went off is because the motor hasnt started yet but idk. like i said its my first and its kicking me in the butt lol
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Before you take the starter out to be checked, leave it in the car and tap it with a hammer lightly while someone is in the car turning the key. If the car starts, then the starter is the culprit. Just trying to save you a trip.
    Member flybird's Avatar
    Jun 2010
    Houston
    Mid Night Blue
    1999 Firebird 3.8 series
    Creative idea! Lol
    Since no one has yet pointed out, check the obvious??
    Battery, battery connections, alternator, fuses, grounds.
    doubt the fuses but somewhere to have a different start!
    pump the gas before starting. btw, any check engine light? If so what are the codes.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Quote Originally Posted by flybird View Post
    Creative idea! Lol
    This is where I would start. All grounds are important so check those first, They check voltage to the starter with the key on and in crank mode. Good luck.
    Oct 2009
    pewter
    99 trans am
    pumpin the gas would do no good...
    Quote Originally Posted by dn1186 View Post
    The battery should be grounded to a post that is on the same fender as the battery. Should see a threaded post. The motor should be grounded in at least 2 places and the PCM also has it's own ground.
  1. Help: car wont start and now gauges wont work!
    By AB'sLs1 in forum General Help
    Last Post: 04-20-2013, 08:54 PM
  2. Z71 wont start
    By duranws6 in forum General Help
    Last Post: 01-09-2013, 07:49 PM
  3. LT1 wont start
    By Bad Co. in forum General Help
    Last Post: 11-18-2010, 07:23 AM
  4. LT1 wont start
    By Bad Co. in forum LT1
    Last Post: 11-16-2010, 05:32 PM
  5. car wont start
    By redss2000 in forum General Help
    Last Post: 06-20-2008, 01:06 PM
