Results 1 to 20 of 25
    Member unibuga's Avatar
    Aug 2010
    bacliff,TX
    blue
    wont start need help!!!
    I went to start my car this morning i push the clutch down turn the key and nothing happens the i thought it was the it jist wasbt recognizing the clutch was down so i by passed the switch and still nothing ....we tried to push start it acts like its goin to run for a second then dies and did the same being pulled by a truck
    I noticed the security light is staying on could the alarm keep it from starting and what would cause this
    It's my daily so any advice i would really appreciate!!!!
    1999 trans am m6,spec stage 3+ clutch,ram air hood,lid,cat back with flowmaster muffler
    1987 firebird formula 350
    Aug 2010
    bacliff,TX
    blue
    Also i tried unplugging the battery and still nothing
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Vats needs to be bypassed is what it sounds like to me.
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    Here's the write up: http://www.ls1.com/forums/f6/how-byp...ur-vats-61262/
    You're ignition cylinder could be out too.
    +1 Sounds like VATS to me. If you have a spare ignition key, you can try that.
    Aug 2010
    bacliff,TX
    blue
    Yeah i just did a search on it and everyone says VATS .....could my kwy be bad also?
    Aug 2010
    bacliff,TX
    blue
    I only have 1 set
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    Yes it could be. Most Keymakers have them too.
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    99% chance its still the ignition cylinder internals though.
    Jeff did this helpful write as well: http://www.ls1.com/forums/f6/vats-di...stance-164731/
    Aug 2010
    bacliff,TX
    blue
    So vat bypass,ignition cylinder, or key are most likely my problem ....if my key is bad does that mean it will show tge wrong ohm reading?
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    Quote Originally Posted by unibuga View Post
    Yes, it could.
    Aug 2010
    bacliff,TX
    blue
    So if my key is messed up can a locksmith still figure out what ohm a new key would need to be?
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    He could try the 1 that is alittle higher resistance or just a little bit lower in resistance.
    But it still could need the bypass.
    Chances are slim that the resistor itself is bad, although anything is possible. Look at the metal tabs on the side of the chip. They should stick out on each side of the key. If they are worn down it may simply be a contact issue in the ignition cylinder. Again, a VATS bypass is your best fix irrespective of whether it is the key or the cylinder at fault.
    Aug 2010
    bacliff,TX
    blue
    Im gonna bypass it tomorrow ....bypassed it should still work even if my key is messed up right?
    Correct.
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    Courtesyvof Jeff's thread, here's the resistor ratings:
    1=392 ohms 2=523 3=681 4=887 5=1130 6=1470 7=1870 8=2370 9=3010 10=3740 11=4750 12=6040 13=7500 14=9530 15=11800
    So if your ohm meter reading 1300 I would try a number 5 or number 6.
    Aug 2010
    bacliff,TX
    blue
    Badass lol....i also have another question. I think my oil pump may be going out at idle im usually at 40 psi but lately it will fluctuate between 30 and 40 i went ahead and changed my oil but still having tge same problem ....when tge pressure drops the car heats up by 5 degrees ....my water and oil levels are good any ideas?
    Quote Originally Posted by KMdef9 View Post
    Unfortunately, I can't take credit for that info as it was copied and pasted from another VATS thread.
    Pittsburgh
    2008 Hummer H3
    You could try replacing the oil presure sending unit, and see if anything changes, but as a general rule with these cars the factory guage can't be trusted for accuracy.
    If you think there is a real oil pressure issue, you could try adding a fitting after the factory sending unit and checking the true presure with a mechanical or electric after market guage.
    The Sunpro mechanical guage comes with the fittings in the guage kit and it's cheap depending on your means. Should give you a more accurate reading.
    Is the car acting up, making odd sounds, anything different in how it runs since you've noticed the guage being strange?
  1. Help: car wont start and now gauges wont work!
    By AB'sLs1 in forum General Help
    Last Post: 04-20-2013, 09:54 PM
  2. Z71 wont start
    By duranws6 in forum General Help
    Last Post: 01-09-2013, 08:49 PM
  3. LT1 wont start
    By Bad Co. in forum General Help
    Last Post: 11-18-2010, 08:23 AM
  4. LT1 wont start
    By Bad Co. in forum LT1
    Last Post: 11-16-2010, 06:32 PM
  5. car wont start
    By redss2000 in forum General Help
    Last Post: 06-20-2008, 02:06 PM
