Results 1 to 3 of 3
Thread: Needed Assistance Lowering
03-15-2012, 08:24 PM #1Member
- Apr 2009
- Pennsylvania
Pewter- 2000 Camaro SS
Ok so I want to lower my car and BMR is having a sale on springs and koni shocks right now.
1993 - 2002 F-Body | Handling Performance Packages | HPP025 - Level 2 Koni Handling Performance Package | BMR Suspension - The Leader in High Performance Suspension & Chassis
I already have a suspension technology front sway bar.
I plan on also ordering the Pan Hard Bar
1993 - 2002 F-Body | Panhard Rods | MPHR002 - Panhard Rod, Chrome Moly, On-car Adjustable, Polyurethane Bushings | BMR Suspension - The Leader in High Performance Suspension & Chassis
Rear Sway Bar
1993 - 2002 F-Body | Sway Bar Kits | SB003 - Sway Bar Kit With Bushings, Rear, Hollow 25mm | BMR Suspension - The Leader in High Performance Suspension & Chassis
And control arm relocation brackets.
1993 - 2002 F-Body | Control Arm Relocation Brackets | CAB002 - Control Arm Relocation Brackets, Bolt-on | BMR Suspension - The Leader in High Performance Suspension & Chassis
Is this all that is needed to complete everything the right way?
03-16-2012, 04:25 AM #2
That should be all of it.
04-03-2012, 08:32 PM #3
The 25mm rear bar is for drag racing, if you want a more autox/road race friendly setup the 21 or 22 is a more popular choice. At the time I lowered my car it had 18" wheels on it. The drop sucked the rear wheel in and I had to get adjustable lower control arms to push it back in the center. If you want lca's I would get one with a heim or roto joint on one end to keep the suspension from binding.
The correct way is a matter of what you want the car to do and how deep your pockets are.
12 Bolt Guru's... Assistance Needed
By ebdboudreaux in forum DrivetrainReplies: 5Last Post: 04-10-2009, 02:08 PM -
What's needed for lowering?
By clint195 in forum Suspension and HandlingReplies: 7Last Post: 08-12-2008, 02:07 PM -
Suspension Diagnostics Assistance Needed!
By matthewaqui in forum Suspension and HandlingReplies: 22Last Post: 08-11-2007, 09:52 PM -
UCA's for lowering 1-1.25" needed?
By ErikElvis in forum Suspension and HandlingReplies: 3Last Post: 08-21-2006, 01:49 PM -
Interior assistance needed
By AFix03 in forum Appearance SectionReplies: 2Last Post: 08-22-2005, 10:12 PM
