08-21-2006, 09:13 AM #1
UCA's for lowering 1-1.25" needed?
Just wondering if UCA's are required to maintain proper alignment on a car lowered 1-1.25". Trying to do the suspension right.
Thanks guys,
Erik05 HEMI Ram, 96 Eclipse GST, 02 SS.
08-21-2006, 01:11 PM #2Member
- South of Heaven
Navy Blue Metallic (NBM)- 2002 Camaro SS
If you are lowering the car an adjustable Panhard bar/rod will help keep your rear centered, and if you are experiencing wheel hop lower control arm relocation brackets will put your LCA's back at a proper angle. Adjustable LCA's are usually set at the stock length and unless you have a really trick setup or custom wheels then they will probably be left at the stock length.
Remember for handling though the more weight on the rearend becomes unsprung weight on a road course.
I would actually recommend rubber/poly LCA bushings instead of poly/poly. For handling the poly/poly will bind...
Good luck with your setup!
08-21-2006, 01:17 PM #3
Thanks! I think rear is taken care of. Have Tubular BMR LCA's with poly/rubber, BMR adj panhard, and BMR bolt in relocation brackets coming. Just wondering about the front UCA and alignment. Still workin on the springs....
Erik
08-21-2006, 01:49 PM #4Member
- South of Heaven
The front will mainly be for weight reduction and then again quick fine alignment adjustment. It is not needed, unless you just absolutely have to have the new upper control arms...
Help: Needed Assistance Lowering
By 1slowbusa in forum Suspension and HandlingReplies: 2Last Post: 04-03-2012, 08:32 PM -
What's needed for lowering?
By clint195 in forum Suspension and HandlingReplies: 7Last Post: 08-12-2008, 02:07 PM -
Lowering Help Needed ASAP!!
By pyro71985 in forum Suspension and HandlingReplies: 2Last Post: 02-08-2007, 08:08 AM -
Lowering springs needed.
By axcellclan in forum Parts Wanted / TradeReplies: 3Last Post: 09-17-2006, 10:46 AM -
4 lowering springs 1.7" to 2" drop +shocks all 4
By boyd in forum Parts Wanted / TradeReplies: 3Last Post: 03-15-2006, 12:49 PM
