Thread: What's needed for lowering?
08-10-2008, 05:16 PM #1
Just want to make sure i have everything i need for loweirng my car. I just ordered Koni shocks, i have bmr springs, adj. LCA, and adj. pan. I remember seeing a couple months ago that there is a part on top of the front shock that likes to rust but cant seem to find that post. If someone could help me out there. I figure i might as well replace it since i am going to have it tore apart anyways. thanks for any help guys.
08-11-2008, 04:51 PM #2Member
- Dec 2007
- Minnesota
pewter- 2002 Tans am WS6 M6
Funny you say somthing about that part! Reason I say that is I'm in the same situation in the process of lowering my car with STRANO springs. Well need less to say it didN't go to well. That part (upper front sock mount) was completly rusted on. Tried for an hour to get it off and all I managed to do was ruin the stock sock mounting stud and still have the thing rusted solid. The peice has a rubber coaring over it so its not like you can heat it. My fix just order 2 new ones from a GM dealership and be done. I'm going to try and get mine this week.
2002 Trans Am WS6 M6
08-11-2008, 04:59 PM #3
08-11-2008, 05:02 PM #4
well in the northland you'll get that rust. i will be ordering strano springs with kyb's.
08-11-2008, 06:27 PM #5
08-11-2008, 07:10 PM #6
08-11-2008, 09:03 PM #7Junior Member
- Jan 2006
- Missouri
Silver- 98
you can get the strut cap mount/bushing? at your local oreilly's or autozone. i had the same problem with mine, and had to cut the complete thing off...PITA!
08-12-2008, 02:07 PM #8
I did ask my parents and they said we are related distantly to a mike if that is the same one you are refering to. They said something about his parents owned the local bar uptown if that rings a bell. Anyways where did you live around here? ANd what is your name maybe i have heard of you.
Help: Needed Assistance Lowering
By 1slowbusa in forum Suspension and HandlingReplies: 2Last Post: 04-03-2012, 08:32 PM -
Question: lowering t/a..will 315's still fit?
By jezzell88 in forum General HelpReplies: 8Last Post: 02-24-2012, 10:33 AM -
Lowering Help Needed ASAP!!
By pyro71985 in forum Suspension and HandlingReplies: 2Last Post: 02-08-2007, 08:08 AM -
Lowering springs needed.
By axcellclan in forum Parts Wanted / TradeReplies: 3Last Post: 09-17-2006, 10:46 AM -
UCA's for lowering 1-1.25" needed?
By ErikElvis in forum Suspension and HandlingReplies: 3Last Post: 08-21-2006, 01:49 PM
