Results 1 to 20 of 23
07-28-2007, 10:37 PM #1Member
- Jul 2007
- Lakewood, California
Red/Silver/Black/Red- TA-G8-Expe-L200-Camaro
Suspension Diagnostics Assistance Needed!
Hello LS1 Owners and the likes!
Yesterday I was in my Expedition on my way to pick up my parents. While on the Freeway, I drove right behind a Red WS6 Trans Am! What a beauty! I could not stop staring! Funny thing is that I have the exact same one parked in my garage that is decked out beyond that one! Ha ha ha ha!
I liked the 4th generation Trans Am so much that I purchased another one today at a used car dealership for $9,200.
I test drove it yesterday and only noticed that the vehicle steering leaned towards the the right. Felt that an alignment would be the fixed. At any rate, as I was pulling into the gas station on my way home from the dealership, I heard squeaking noises from the rear. I was disappointed at the sound of this and will submitting the vehicle back to the car lot for repairs. The vehicle has 110,000 miles on it, though still looks very sharp for a 2000 Trans Am.
Now, as I forced the TA rear end up and down, the squeak is triggered. What do you possibly think is defective: Shocks, the Struts, possibly the spring. With me alone, I was not able to really audibly decipher whether it was coming from the left or even the right side..... sound to come from right in the rear middle.
Your diagnose would be most welcome and very appreaciative. I want the used car repair/mechanic to properly fix the problem when I drop it off. Used car dealership typically want to rid the vehicle off of their lot ASAP and wipe their hands clean. According to their contract, they only cover engine and transmission for 30 days or 1,000 miles.
Thank you for your assistance,
Matthew
P.S. Brakes, parts of the engine, exhaust I can do well, but when it comes to vehicle suspension diagnostics, I'm a fish out of water. Thanks.
07-28-2007, 10:40 PM #2
Subscribed. I have the same squeaking you're describing.
07-29-2007, 02:25 PM #3Member
- Apr 2007
- San Diego
Red- 2002 T/A
Mine has the same problem from time to time. It goes away when it rains or I drive through a large puddle. I'm willing to bet it's a rubber bushing or upper shock mount. I'll know for sure when I install my UMI panhard bar and lower control arms. I'm just waiting on my lowering springs and new shocks to come in. It's nothing to worry about, but I agree it is quite annoying. If that doesn't take care of it then it has to be the sway bar bushings. try spraying some silicone lube in a few of your bushings to see if it helps for a while.
07-29-2007, 02:42 PM #4
check the panhard rod and trailing arms.
07-29-2007, 03:41 PM #5
07-29-2007, 04:01 PM #6Member
- Apr 2007
- San Diego
Red- 2002 T/A
On the control arm pic the the control arm is number 3. It has bushings on both ends. On the shock pic the rubber strut mounts are numbered 3 and 5. The sway bar bushings are at the end of the line that goes from the number 2 nut up to the bushing. You might want to raise the vehicle and support it on jack stands before doing any work. If you remove anything yourself remember to do one side at a time.
07-29-2007, 04:04 PM #7
Cool thanks! Are the panhard rod and trailing arms in those pictures?
07-29-2007, 04:07 PM #8Member
- Apr 2007
- San Diego
Red- 2002 T/A
The panhard bar is number 5 in this pic. Control arms are another name for trailing arms.
Last edited by LS1_TA_2002; 07-29-2007 at 04:11 PM. Reason: I said number 4 but it's number 5
07-29-2007, 04:10 PM #9
07-30-2007, 09:23 AM #10Member
- Jul 2007
Lubricating the Bushing
Thanks for the suggestion. A coworker of my mentioned about the rubber bushings as well. I will spray some lubricant on and test the vehicle again. Whatever it is, I have to figure it out soon and return it to the Used Car Lot to have them do the repair soon before this 30 day is up on the vehicle.
Thanks LS Buddy!
Matthew
07-30-2007, 09:38 AM #11Member
- Jul 2007
Squeak Resolution
Hello Buddy,
Were you able to resolve your squeaking from our LS1 Friend of this thread? I'm going to try a little lubricant on the rubber as suggested.
Matthew
07-30-2007, 10:01 AM #12Member
- Jul 2007
The Suspension System
thank you for sharing the suspension diagrams. Are these general suspension images or are the exact diagrams Belong to Trans Am...
By the way, you mentioned struts.... who do LS1 TAs have? Struts in the Front and Shocks in the back? Or Struts on all sides?
Thanks and take it easy Man!
Matthew
07-30-2007, 01:00 PM #13Member
- Apr 2007
- San Diego
Red- 2002 T/A
These are factory firebird diagrams and yes I meant shocks. Hope it helps.
08-02-2007, 07:28 AM #14Member
- Jul 2007
The Rear Creaking Noise--------------
Well buddy.....
Here are the results.
The mechanic replaced---- I don't even know what in the hell it's called but the two little arms are not even in your diagrams for me to point out.
After 7 years of environmental wear and tear, all TAs will likely have this creaking problem in the rear suspension from these little arms. I would say these little support arms looks like mini Shocks without any springs in them. On there tip are urethane pushings that become brittle from the wear and causes the creaking noise when rear downward/upward pressure is applied.
See if you can locate an image of it since you have access to the other ones.
It's about ye 7 inches long with bushings, washers, etc.
I'm sure with a little grease like you mentioned would have done the trick, though I don't know if these brittle urethanes would in time fall apart.
And you are right, driving through water etc. would probably eliminate the noise for those bushings are lubricate.
Matthew
P.S. After bringing home the vehicle, I noticed that it leaked minor oil. Not sure from what part of the engine but will figure it out. If I can do the job myself and eliminate the mechanic, I will. The vehicle is abuse at the mechanic with the windows left down all day and grease fingers all over the car.
08-03-2007, 12:38 AM #15Member
- Apr 2007
- San Diego
Red- 2002 T/A
Is it this?
08-03-2007, 07:23 AM #16Member
- Jul 2007
GM Modifications
LS Buddy!
That's it. What is that part called? There are many urethane bushings in there as you can see?
They replaced it without any charge to me, though I would like to find out how much that part cost. It's too unfortunate that these 4th generation Fbodies entail too many defects through wear and tear.
Just last week I was discussing with my Dad about the Plastic headlight plastic headlight gear that is screwed up on his 89 Firebird. Evidently these headlight gears will go bad on all Firebirds through time because the teath of them will be worn out. In 89, GM also had the automatic plastic trunk lock down. These plastic lock down were poorly supported and came loose from the trunk after 3 or 4 years.
Unfortunately, I don't think that 89 Firebird has the problem with the suspension part that I am having.
It's too unfortunate that GM did not resolve the headlight gear issue with their 4th Generation, though they did take care of the trunk latch.
Matthew
08-03-2007, 12:10 PM #17Member
- Apr 2007
- San Diego
Red- 2002 T/A
08-03-2007, 12:54 PM #18Member
- Jul 2007
Thank you
Gracias Amigo! That's it, the Sway bar link. Evidentally those bars entail much movement as the vehicle girates up and down to create constrant friction against each other.
Matthew
08-03-2007, 09:27 PM #19Member
- Jul 2007
Your Diagrams
As I'm sitting here go over the diagrams and round filing the printout for future references. I was thinking. Where did you pull these diagrams from? Are they from Chilton's?
Thanks LS1 Buddy!
Matthew
08-03-2007, 10:08 PM #20Member
- Apr 2007
- San Diego
Red- 2002 T/A
Help: Needed Assistance Lowering
By 1slowbusa in forum Suspension and HandlingReplies: 2Last Post: 04-03-2012, 08:32 PM -
Needed: SLP suspension expert
By hitempguy in forum Suspension and HandlingReplies: 20Last Post: 06-26-2009, 11:43 AM -
12 Bolt Guru's... Assistance Needed
By ebdboudreaux in forum DrivetrainReplies: 5Last Post: 04-10-2009, 02:08 PM -
Suspension set up needed
By supaxero in forum Suspension and HandlingReplies: 5Last Post: 03-10-2009, 08:27 PM -
Interior assistance needed
By AFix03 in forum Appearance SectionReplies: 2Last Post: 08-22-2005, 10:12 PM
