Results 1 to 20 of 26
03-12-2012, 06:26 PM #1
Surging idle, before and after new IAC valve
I have a surging problem, about every 3 seconds the car revs slightly. with the IAC unplugged, it stops. idles normal. replace the IAC valve today, and it still surges. i believe the TB had been polished. i cleaned the maf, TB, and IAC opening not too long ago. just surged a little faster.
There is a ticking coming from the intake, do not know if it is related or not.
http://imageshack.us/clip/my-videos/526/2x2w.mp4/
thanks.Last edited by JacobLS1; 03-12-2012 at 06:42 PM.
03-12-2012, 06:35 PM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Sounds like a vacuum leak possibly. Check all the vacuum hoses for cracks or even being disconnected. If you can't narrow it down, you can spray a little starting fluid around different areas, and when the idle raises, check that area.
03-12-2012, 06:42 PM #3
I've tried that before and nothing happened. so if there is one, its that small.
03-12-2012, 06:47 PM #4None Shall Pass
- Jan 2010
Another thing you might check is the wiring for the sensor. Make sure the connections are good, and none of the wiring is pinched, broken, or shorting/grounded.
03-12-2012, 07:46 PM #5
Have you done the TPS and IAC reset? When I was cammed sometimes my car wouldn't grab an idle after I disconnected the battery. I would reset the TPS and IAC and the car would idle fine.
You unplug both the TPS and IAC. Key the car to the ON positiong. Don't start it. Wait 30 seconds, key off. Plug the sensors back in and start the car.
When you're adjusting the TB set screw to get your IAC counts into the right range you have to do this each time. Perhaps yours is slightly off and just needs to be relearned.
03-12-2012, 08:05 PM #6
Another thing to consider is that new parts do not always equate to good parts.
03-13-2012, 12:00 AM #7
03-13-2012, 02:59 PM #8
Tried resetting the iac and tps. Cleaned the iac port, and plug. Cant see any physical damage in the wires.
IAC counts??Last edited by JacobLS1; 03-13-2012 at 03:12 PM.
1998 Z28: Bolt-ons, Stage ? 4L60E. 250rwhp@6500Ft (R.I.P 5/1/2013)
1998 Mystic Teal Trans Am: Bone stock. (In process)
03-13-2012, 03:26 PM #9
03-13-2012, 03:40 PM #10
Like a tech 2? No. I can probably use one at my brothers work. It set off a p0507.
What kind of info? so when I use the scanner.
Found this..I think its coolant. Rock hard..
03-13-2012, 03:44 PM #1111 years of bangin gears
- Jan 2009
- North Jersey
I think that is epoxy. I have read some people use epoxy when they port/polish throttle bodies. I think the epoxy is used to fill the IAC hole and bypasses it.
03-13-2012, 04:45 PM #12
smelt like coolant.. maybe its the coolant line right under the throttle body. i took it out, in hopes of the IAC getting more air. its more quiet. almost seems more subtle. i also hooked the AIR hose back up, but i don't think it helped. no more noise from the AIR pump though.
03-13-2012, 04:52 PM #1311 years of bangin gears
- Jan 2009
- North Jersey
Was the AIR hose ever disconnected before?
03-13-2012, 06:01 PM #14
Ever since I bought it. EGR was removed. Assumed the AIR pump was as well. Bought it two years ago. Problem started last october.
Neglected to mention. Its only when the engine is warm.Last edited by JacobLS1; 03-14-2012 at 04:41 AM.
03-15-2012, 12:49 PM #15
Covered the hole in the throttle body, no more surging. The idle still hangs at 1500 in neutral. Few steps closer atleast.
03-15-2012, 04:32 PM #1611 years of bangin gears
- Jan 2009
- North Jersey
Just checked over the net. When was the last time you checked your PCV?
03-15-2012, 05:10 PM #17
Never. Just see if its clogged?
Pass. side, adjacent to the tb? I don't see anything...Its an ls6 intake, egr was removed. don't know where the occur would be relocated to. There is something running alongside the intake(pass side)Last edited by JacobLS1; 03-15-2012 at 05:38 PM.
03-15-2012, 06:35 PM #18
make sure the whole hose/pipe that comes out on the left side of the TB is intact. In that tubing is the PCV. I will check that the PCV is moving free, inspect the rubber pieces where it connect to. Check the whole tubing that goes around the back of the intake. There is a rubber Y behind the intake that roots and causes a vaccum leak. Check the elbow that goes to the drivers side valve cover as well. there is a few pieces of plastic that meltdown if are not in the right place and cause a leak too.
03-15-2012, 06:41 PM #19So it's probably the bulge that's runs along the pass. side of the intake under the fuel rails. Ill check the whole hose in the morning. Kinda tempted to pull the intake to check the valley anyway.
Originally Posted by JayTA98:2756659
03-15-2012, 06:44 PM #20
check that pcv hose where it bends to go into the intake.....they like to crack on the backside of that bend.
Help: Surging idle
By 97ws6 in forum External EngineReplies: 10Last Post: 11-10-2010, 08:13 PM -
idle air control valve???
By unibuga in forum General HelpReplies: 19Last Post: 09-30-2010, 06:02 PM -
erratic idle and surging at low speed
By shady milkman in forum External EngineReplies: 19Last Post: 07-01-2010, 09:35 AM -
Help: low, rough, surging rpm at idle after hot start
By wcidioti in forum General HelpReplies: 4Last Post: 05-11-2009, 11:01 PM -
Need a Idle Air Control Valve
By zbizkit in forum Parts Wanted / TradeReplies: 0Last Post: 06-22-2007, 04:45 AM
