05-10-2009, 06:20 AM #1Junior Member
- May 2009
- sgh
blonde- 2004
low, rough, surging rpm at idle after hot start
hello,
having a caprice/statesman 2004 ls1. problem is when starting car while it is still hot from the previous start, the rpm reading goes as follows. starts at 1000, then a few seconds decreases beyond the normal 700-800 to nearly 500, at that point the engine shivers, and if you press on the gas while in drive it will not produce power to move the car.. i would wait for a minute and the rpm would suddenly jump up from 500 up and down quickly a few times, stabilising at the normal 700-800.. then i can drive normally. other than that it is very good in all aspects..
05-10-2009, 06:25 AM #2
The IAT sensor is in a bad spot and is getting heat soaked when the car sits for a short period and is restarted (like stopping at a gas station). With it reading falsely hot, your mixture is lean, that's why the engine is weak.
What platform are you using to tune with?
05-10-2009, 12:10 PM #3Junior Member
- May 2009
- sgh
blonde- 2004
aha, makes much sense..
anyway, i forgot to mention that while this happens the engine check sign would come on.. but that is just a consequence.. where is the iat sensor located ?
the ls platform
05-10-2009, 10:32 PM #4
I mean what tuning platform as in which tuning suite.... this is the TUNING section
The SES should not be coming on though. Without the scanner in a tuning package, our ability to trouble shoot is greatly hampered.
05-11-2009, 11:01 PM #5Junior Member
- May 2009
- sgh
blonde- 2004
i dont know info about the platform or tuning.. as i havent come accross that..
anyway, while this low rpm shivering happened earlier i poured water over the stem of the intake (maf, iat) after which the engine self corrected (rpm). i will probably add insulation instead of relocating.
thank you,
Help: Rough Cold-Start Idle
By PonyCAR in forum Firebird / WS6Replies: 8Last Post: 05-15-2017, 01:37 PM -
Help: Surging idle, before and after new IAC valve
By JacobLS1 in forum General HelpReplies: 25Last Post: 03-16-2012, 09:33 AM -
Help: Surging idle
By 97ws6 in forum External EngineReplies: 10Last Post: 11-10-2010, 08:13 PM -
Help: intermittant rough idle, off idle hesitation
By Matto4785 in forum General HelpReplies: 1Last Post: 09-21-2009, 05:12 AM -
rough idle at start up
By 2001TransAm in forum General HelpReplies: 7Last Post: 08-05-2009, 11:06 AM
