Results 1 to 20 of 20
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    erratic idle and surging at low speed
    Hey everyone
    i installed a ls6 intake manifold two days ago. Well everything went according to plan...broke my oil pressure sending unit and swore more then a sailor. Well When i started my car up (98 trans am, no internals mods) I noticed erratic idle..the car would idle real low..the 500rpm range. The car never has stalled but gets close. When i let it warm up it will flucuate between 500 all the way up to 2k..however when its in park it ranges from 1k-2k..in gear drops to 500.
    I unplugged my maf and the idle stopped searching so much and sounded good at a little under 1k...but then in neutral it was up to 1500..I read here that the IAC could be dirty. It was filthy but after i cleaned it and did a pcm relearn it still searches a lot..with terrible lag in low end throttle response and low end driveability and bad idle quality...any suggestions will be greatly appreciated
    mercersburg pa
    hugger orange
    2004
    sounds like it might be s bad vacuum leak. did you plug the brake booster and heater control line back into the back of the manifold?
    Shepherd, Michigan
    98' trans am
    Quote Originally Posted by mark21742 View Post
    yeah...i'll check it again tomorrow...runs sooo good though in mid-high
    Chicago IL
    2000 A4 WS6
    I know its a totally diffrent beast but when I had my srt4 I had damn near the same problem and It was a mainfold gasket leak. Sounds like a gasket and or vaccumm leak... spray down around the intake and see if idle changes.....
    Jeff
    Shepherd, Michigan
    98' trans am
    hmm we didn't have a inch pound torque wrench with us so we snugged them..i wonder :| what do i spray by the gaskets?? maf cleaner( it is safe for electronics etc.
    mercersburg pa
    hugger orange
    2004
    carb/ brake/ maf cleaner, any should work. when you spray it just listen for a change in the way the motor is running
    15 sec. Oh yeah, its fast UTVols98's Avatar
    Forest Lake, MN
    maroon
    2000 Z28
    Tune it and mess with the TPS. Looks like the same problems I had before and the tune fixed it.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Quote Originally Posted by UTVols98 View Post
    I would bet 5 bucks on the tps Jordan. Mine didnt throw a code for about two weeks. Same issues.
    Shepherd, Michigan
    98' trans am
    hmm i am 98% sure its a vacuum leak in the brake booster line to the manifold..however if i change that out and still no change..i will replace the tps...how much is a tps ? and does anyone know the size of hose for the brake booster so i can replace if needed ?
    Beaver Dam KY
    79 T/A -91 Firebird
    I do believe it is 1/2 inch. TPS brand new with warranty was 27 here.
    mercersburg pa
    hugger orange
    2004
    I think it around 3/8".
    Beaver Dam KY
    79 T/A -91 Firebird
    3/8 is the pcv system size. A bit too small.
    Shepherd, Michigan
    98' trans am
    ok it's a vacuum leak and its coming from the protruding fitting on the back..where the hvac and brake booster go into...its gasket is showing ..so my question is how do i remove it/put it back on.. :S
    Beaver Dam KY
    79 T/A -91 Firebird
    Isnt that where the map goes?
    Shepherd, Michigan
    98' trans am
    yes..but also the hvac (small hose fitting..and the brake booster (large hose fitting go on too!)
    Shepherd, Michigan
    98' trans am
    on one side there is alot of play ..like its about to fall out...and i can see the orange gasket on that side (the brake booster side)
    Member goof4080's Avatar
    Jun 2009
    lisle, il
    Red, Black
    98 T/A M6, 79 T/A 6.6L
    how the hell do u guys see back there. even a mirror sucks.
    Orlando, FL
    Mean Black
    If the orange gasket that belongs to the MAP sensor is worn it can leak. Was that a new intake or used? Make sure that the plastic elbow piece is not actually leaking or it has a crack.
    Shepherd, Michigan
    98' trans am
    woah old thread. well it was used and i found out it had a small crack in it...more than likely from me over torquing it. so i jb welded it and it is fine. however i would like to change out the map sensor one of these days. most all of the sensors are 12-13 years old and have close to 100k on them.
    Shepherd, Michigan
    98' trans am
    Quote Originally Posted by goof4080 View Post
    what can we say...
  1. What's Your Idle Speed?
    By Naaman in forum General Help
    Last Post: 01-13-2013, 02:24 PM
  2. Help: Surging idle, before and after new IAC valve
    By JacobLS1 in forum General Help
    Last Post: 03-16-2012, 09:33 AM
  3. Help: Surging idle
    By 97ws6 in forum External Engine
    Last Post: 11-10-2010, 08:13 PM
  4. Help: low, rough, surging rpm at idle after hot start
    By wcidioti in forum General Help
    Last Post: 05-11-2009, 11:01 PM
  5. idle speed
    By m1a2d3 in forum Camaro / SS
    Last Post: 09-15-2008, 12:46 PM
