Results 1 to 20 of 20
Thread: idle air control valve???
09-27-2010, 12:41 PM #1
i was at a light then my car almost stalled twice then my ses light came on...my car has been idling kinda rough for a while could this be the problem?
they ran the code at the auto parts and this came up
and can i still drive it like his? i drive like 50 miles a day and dont get paid till friday
09-27-2010, 12:47 PM #2
also its a 99 trans am m6 with a lid and a catback
09-27-2010, 12:56 PM #3King 0f n00bz
- Jan 2006
- Shepherd, Michigan
ehhh..id first try to clean the iac...and see if that fixes it ...then reset it and if that doesnt work...replace it ..if you deal with it almost stalling all the time...then yes you can drive with it failing
09-27-2010, 01:02 PM #4
where is it located exactly? how do i clean it? ect...?
09-27-2010, 01:15 PM #5
09-27-2010, 01:18 PM #6
ok ill try that before i buy the sensor
09-27-2010, 02:37 PM #7
Heres a pic, circled in red..
09-27-2010, 04:46 PM #8Senior Member
- Jan 2010
- texas
silver- 2000 formula
can you remove it from the TB......or just remove the TB to get to it?
09-27-2010, 04:48 PM #9
I think I can just take it off
09-27-2010, 05:36 PM #10
09-27-2010, 07:12 PM #11
Ok I cleaned it and put it back on and the code went away and it was still running bad when I noticed a large vacuum line on the intake manifold right behind the throttle body was completely rotted off
09-27-2010, 07:15 PM #1211 years of bangin gears
- Jan 2009
- North Jersey
Time to replace that hose.
09-27-2010, 07:49 PM #13
09-28-2010, 03:44 AM #14Senior Member
- Apr 2008
- Madison, WI
I'm guessing its this infamous spot
09-28-2010, 07:40 AM #15
DyYup this is the exact line its completely in half ....I just bought the car bout a month ago and looking at it looks like its been atleast leaking for a while....will it run better after this?..... also can use just any line to fix it because it might be hard just to get that short little peice by its self
09-28-2010, 08:09 AM #16
09-28-2010, 03:12 PM #17Senior Member
- Apr 2008
- Madison, WI
3/8"(I believe) rubber fuel line can fix that small section
09-28-2010, 03:17 PM #18
09-29-2010, 10:04 PM #19Senior Member
- Jan 2010
- texas
i took off my TB tonite......it was a freakin mess......used 2 cans of TB cleaner to get it half decent.....it does idle a little better now
09-30-2010, 06:02 PM #20Senior Member
- Apr 2008
- Madison, WI
LS6 valley cover and a catch can should help keep the oil out of the intake and help keep the TB cleaner.
How do you check voltage going to Idle air control valve?
By Street Fighter in forum General HelpReplies: 3Last Post: 05-28-2015, 03:08 AM -
Help: Surging idle, before and after new IAC valve
By JacobLS1 in forum General HelpReplies: 25Last Post: 03-16-2012, 09:33 AM -
Question: High RPM's? Idle air control opens?
By Shannon2356 in forum Camaro / SSReplies: 26Last Post: 04-02-2009, 08:34 PM -
Help: Idle control valve
By mo$z28 in forum General HelpReplies: 19Last Post: 06-12-2008, 08:17 PM -
Need a Idle Air Control Valve
By zbizkit in forum Parts Wanted / TradeReplies: 0Last Post: 06-22-2007, 04:45 AM
