Thread: loud bang in rear area
02-21-2012, 04:39 PM #1Member
- Nov 2009
- Norfolk, Nebraska
- 2002 Camaro Z28
As stated, when I hit bumps just right I get a heck of a bang coming from right rear area. Almost sounds like if you would imagine a window falling down in a door. I can hit the same bump 10 times and it will do it half the time. I ordered rear control arms, panard bar and a set of rear shocks. I know its none of these things but decided to do the rear suspension this year. Could it be a spring banging around?
Junkyard bought and "refurbished" 2002 Camaro Z28 - Pacetter Race LT's, TS&P ORY, Frost tune, Magnaflow, Ported TB, SLP Lid, Circle D 3000, 3.73's, SFC's.
2009 Silverado Z71 - Magnaflow
2008 Impala LTZ - Wife didn't want the V8 SS!
02-21-2012, 05:15 PM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
It's possible. Do a good inspection and look for any areas of contact. It may even be something simple like the exhaust is contacting the axle, a broken exhaust hanger, ect.
02-21-2012, 05:49 PM #3
after doing my SFC's i got the same issue... im pretty sure i didnt tighten my control arms enough because as well as you when i hit "some" bumps it clunks pretty good i would check your control arms out... make sure they are tight enough!!!
02-21-2012, 06:35 PM #4
yep.....sounds like your control arms aren't torqued down enough. Retorque those and I bet the noise goes away. Remember to torque those with the suspension loaded.
02-21-2012, 06:57 PM #5
Might also want to look at the size of the holes in your lcas and the hole size in the frame. They don't correspond, and when you hit a bump, the lcas move. At least in my case.
02-21-2012, 07:12 PM #6
I'm guessing the exhaust is hitting where it goes over the axle or maybe your bump stop is deteriorated on that side.
02-22-2012, 07:21 AM #7Member
- Nov 2009
- Norfolk, Nebraska
- 2002 Camaro Z28
Thanks guys. I'll check everything when I do my new control arms and shocks. I zipped those bolts on with an impact and thought I had them plenty tight but I will check.
02-22-2012, 12:38 PM #8Spaz is My Mentor
Don't forget to check the bump stops too.
I had the same problem and was fixed when I did my LCA's so I agree with everyone else to check the LCA's. Bad bushings also could be the problem.
rear end loud noise
By ice97ta in forum GTOReplies: 15Last Post: 10-28-2012, 09:06 AM -
Help: loud bang/clunk from tranny area
By wileyCoyote in forum General HelpReplies: 15Last Post: 05-06-2011, 04:24 PM -
Very Loud noise coming from trans or rear-end?
By greenvilleTA in forum DrivetrainReplies: 9Last Post: 10-04-2008, 10:14 PM -
Bang in hatch area over big bumps
By proroc in forum Firebird / WS6Replies: 8Last Post: 07-07-2006, 05:37 AM -
1 rear bang
By third_shift|studios in forum General HelpReplies: 1Last Post: 09-06-2005, 05:45 PM
