Results 1 to 16 of 16
    Centerville OH
    blue
    1999 TransAm
    Help: loud bang/clunk from tranny area
    Well, i just had a new clutch installed a week ago. Everything seemed to be running fine.. Now fast forward to today, i'm driving to work as usual, and go over a bump, i think it's a bridge expansion joint, just like everyday, and hear something like "rattle rattle...bang". The noise sounds like it's in the tranny area, definitely under the floorboard/tunnel. It's like something broke loose from going over this bump.
    Now, it makes this "rattle, bang/thud, rattle",.. kinda noise when going over rough road/bumps or between coastdown and speed up. i drove it the rest of the way to work like this, being i was almost there. it's hard to explain the sound, ...it sounds as if there were a big rock down there that rolls/bounces around hits the floorboard/tunnel..?
    i looked underneath now that it's parked in the lot, ...didn't see anything hanging, but didn't feel around either because the exhaust and everything still hot and i'm dressed for work.. i hope it's ok for me to try and drive this a few mile to the shop for inspection?
    sounds like either your exhaust is hitting the floorboard or you have a busted tranny mount. Does it do it if you take off fast or just over bumps?
    Could also be a broken or loose torque arm mount... but like 0rion suggested, most likely a transmission mount. Could be the shop didn't get something tightened down all the way and it let loose.
    good point......and since it's so close to the install the first thing I thought of was something left loose or came back loose. I would take it back to whoever did the work and have them look at it.
    Centerville OH
    blue
    1999 TransAm
    if it's the tranny mount or torque arm, is it safe to drive it a few mile to the shop? before i parked it, i didn't have any problem shifting gears or using the clutch... just the bang/clunk noise and a slight whine sound...
    East of Cleveland, Ohio
    99 WS.6 - Modified
    You should be okay to drive it to the shop, just take it easy.
    yeah...unless it's about to fall out it should be fine. I wouldn't beat on it or anything like that but you should be able to just drive it without an issue
    old timer blue02Z's Avatar
    2002 Z28
    i second the torque arm mount. makes since if it clunks on accel and decline
    98 T/A w/ mods, 00 FBVert
    This. I had the exact same sound and description happen when I did my first clutch replacement. I guess I didn't tighten down the bolt that the TA connects to the the transmission. Scared the hell out of me when it first happen.
    Quote Originally Posted by wileyCoyote View Post
    you'll be fine... just take it easy on the way there... i actually snapped my stock TQ arm in half right where it bolts to the rear...
    Centerville OH
    blue
    1999 TransAm
    Ok, i have an update:
    got it to the shop, ..apparently they forgot to tighten a bolt on the torque arm. ...so hopefully problem solved.. but, jeez, w/ all the racket it made, it sounded as if the tranny was loose and going to fall out!
    thanks for all your inputs/replies!
    2002 Z28
    No problem
    i'd unbolt it and take a look at the bolt holes... the stockers are weak and flimsy... i bet the banging around made the bolt holes into ovals...
    Apr 2009
    Pennsylvania
    tranny mount
    99 WS.6 - Modified
    This.
    Member mikey gavin's Avatar
    Oct 2010
    bruce
    bright red
    1998 formula trans am m6,
    same thing happened to me i thought i exploded the tranny er the motor or something. it turned out to be u joint came apart
  1. WS6 tranny area clunk during launch?
    By eteller in forum General Help
    Last Post: 12-01-2012, 04:14 PM
  2. loud bang in rear area
    By JunkyardZ in forum Suspension and Handling
    Last Post: 02-22-2012, 12:38 PM
  3. **loud clunk**
    By SurfaceGod in forum General Help
    Last Post: 07-14-2010, 05:21 PM
  4. *Clunk*? Tranny? rear end?
    By gimmeadonut in forum Automatic Transmission
    Last Post: 07-24-2007, 08:20 PM
  5. loud clunk
    By 01outlaw in forum Drivetrain
    Last Post: 02-28-2007, 05:48 AM
