07-03-2006, 06:46 AM #1Junior Member
- Jun 2006
- NJ
Red- 1999 WS6 Trans Am
Bang in hatch area over big bumps
Hey guys, my car makes this banging sound from the hatch when i go over big bumps. I think its the hatch, but its shut and feels very tight. Does anyone else have this problem? If so what was it and how did you fix it?
Thanks!
07-03-2006, 05:08 PM #2
I havent had this problem. But maybe your lights could be loose. Pull back the carpet and make sure all those bolts are tight. Just a thought tho.
07-03-2006, 05:12 PM #3
im pritty sure that the hatch has a litle leway.. i think it might b normal tho. when it is closed, try pushin it down while its closed.. see if it goes down anymore. if so thats what it probably is.
07-03-2006, 07:22 PM #4I Love My Bong
- Sep 2005
- Hot Springs, AR
Midnight Blue- 99' Trans Am
Have you checked your spare tire or jack?
07-03-2006, 08:56 PM #5Member
- May 2006
- New Jersey
Silver- 1998 Trans Am
i have the same problem!....have no clue what it is
07-06-2006, 05:12 AM #6Junior Member
- Mar 2006
- IL
Pewter- 2001 Trans Am WS6
My Formula has this problem, and I'm pretty sure on it a bad spring was the cause. When I went over large bumps, especially with passengers in the back, the wheel would bottom out creating a loud 'thud'. Your issue may be different though.
07-06-2006, 06:17 PM #7Junior Member
- Jul 2006
- Indianapolis
Dark Green- 1991 Firebird
I also had the same problem, come to find out like easyericvan said, it was my spare tire bouncing up and down.. LOL.
07-06-2006, 09:46 PM #8
My first thought was the spare tire and jack. Second thought was a lower control arm needed torqued down but that's more of a pop or thud and sounds like it's coming from under the rear seat. Check your jack.
07-07-2006, 05:37 AM #9Local Idiot
- Nov 2005
- Wilmington, De
Cyclone Grey Metallic- 2005 GTO
If it's not the jack/spare, check the bump stops on the bottom of the hatch. They are at the far rear corners of the hatch and keep it tight. I had this problem on my old 93 bird, those bump stops were toast. Even if yours look fine, screw them out a bit to keep the hatch tighter.
back hatch rattling when go over bumps
By ASh302 in forum Firebird / WS6Replies: 23Last Post: 04-11-2015, 06:46 PM -
loud bang in rear area
By JunkyardZ in forum Suspension and HandlingReplies: 7Last Post: 02-22-2012, 12:38 PM -
Help: loud bang/clunk from tranny area
By wileyCoyote in forum General HelpReplies: 15Last Post: 05-06-2011, 04:24 PM -
Anyone got a good pic of their hatch area?
By StuntmanMike in forum Firebird / WS6Replies: 8Last Post: 09-05-2007, 04:53 AM -
anyone tried mounting a 4x6 plate in the hatch area?
By ScrapMaker in forum Stereo and ElectronicsReplies: 12Last Post: 03-26-2006, 06:22 PM
