Results 1 to 3 of 3
Thread: oxygen sensor heater codes
01-05-2012, 06:32 AM #1
since installing my new engine I've been getting p0135,p0155 codes. The circuit tests fine I'm assuming it's because of the cam. MY question is can the heaters be turned off via tuning without any adverse effects? As always any advice is greatly appreciated.
01-05-2012, 07:23 PM #2
you can turn off just those codes......how old are your sensors? If you have headers that's most likely the reason for the heater codes. I solved my heater code issue by using bosch 13111 sensors. Had those in a few years now and haven't had a single heater code since installing them.
01-06-2012, 04:24 AM #3
thanks i will give those a try.
more oxygen sensor help
By 2002 in forum General HelpReplies: 8Last Post: 08-21-2016, 06:17 PM -
oxygen sensor simulator help
By Ghawk996 in forum External EngineReplies: 13Last Post: 11-16-2012, 03:32 AM -
Throwing Oxygen Sensor Related Codes
By GULLETT17 in forum External EngineReplies: 43Last Post: 10-22-2008, 10:31 PM -
Oxygen Sensor
By NJ2002WS.6 in forum General HelpReplies: 9Last Post: 09-04-2008, 04:09 PM -
Oxygen Sensor 2000 Z28
By gokussx4 in forum Camaro / SSReplies: 7Last Post: 09-01-2006, 01:52 PM
