Results 1 to 14 of 14
    Member Ghawk996's Avatar
    Knoxville
    oxygen sensor simulator help
    hey guys I haven't been on here in a while but am in need of some help with my 99' Chevy Blazer.
    The problem is that someone cut off my catalytic converter so now I was wondering if anyone knows where I can get a direct plug in o2 simulator or do I just need to buy an aftermarket Catalytic converter from Summit Racing. Plus money is kinda tight at the moment.
    Thanks
    Just ignore the check engine light and keep driving it. That is your cheapest and easiest fix.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Yup, Jeff is correct. It will not harm your engine at all to drive the car without a catalytic converter. Now, if you have to get emissions in your state then you'll need to get the code cleared. Replacing the cat, getting an O2 simulator, or getting a Frost tune to remove it would be your options for that. Just a FYI, the 02 simulators are prone to be problematic.
    Knoxville
    Well without the cat the o2 sensor is not working correctly and the Blazer is running very poorly and burning the fuel.
    Member SuperSSguy's Avatar
    Jul 2012
    NorCal
    Sunset Orange Metallic
    2002 Camaro SS M6
    OP are you talking about the rear 02`s? cause that shouldnt effect the way it runs.
    Quote Originally Posted by Ghawk996 View Post
    Ummm. No. The lack of a converter is not adversely affecting the OP's engine. The rear O2 senders have absolutely nothing to do with fueling. All they do is report back to the PCM and tell it if the converters are functioning properly.
    Pittsburgh
    2008 Hummer H3
    Not having a cat or a funtioning rear 02 sensor will in no way effect the way a 4.3L v6 consumes fuel or operates.
    Time to start searching for other issues.
    Knoxville
    Well I guess that I need to check this further because it is over fueling and not running at full power. The motor was running strong prior to an engine swap from another blazer and while I was doing this someone cut the Catalytic converter off along with the pipe and sensor. I guess I will need to check the timing.
    Any suggestions on why it is running really rich with a strong gas smell.
    Are you running a custom tune from the prior engine setup? Is it the same MAF?
    Pittsburgh
    2008 Hummer H3
    So this is a junk yard motor? If so I'd have a hard look at the front 02 and wires for damage.
    Are you using the salvage engine wire harness? Is the service engine light flashing?
    Knoxville
    The motor is out of another blazer my sister wrecked which was running strong. I bought another blazer which had a blown engine. So I just figured that it was the sensor since it was missing. I am open to suggestions tho.
    Do you have access to a scanner that will show your fuel trims?
    Pittsburgh
    2008 Hummer H3
    Ok, so it is a salvaged engine. It's very important you answer the questions we ask if you want us to be able to help you.
    Again,, is the service engine light flashing?
    Did you change the wire harness in any way, whether from one engine to the other, or make any repaires such as splices etc?
    Are the blazers from the same year or are they different?
    Did you exchange the PCM from one to the other?
    Did you hook everything up (aside from the rear o2 sensor) without leaving anything disconnected?
    Agree. Sounds like there is more going on here than just a simple sensor issue.
  1. more oxygen sensor help
    By 2002 in forum General Help
    Last Post: 08-21-2016, 06:17 PM
  2. Question: Walker oxygen sensor (has anyone used these)
    By allbaugh_04 in forum General Help
    Last Post: 11-12-2009, 07:23 PM
  3. Oxygen Sensor
    By NJ2002WS.6 in forum General Help
    Last Post: 09-04-2008, 04:09 PM
  4. o2 solenoid oxygen sensor
    By feras in forum External Engine
    Last Post: 04-19-2007, 02:50 AM
  5. 97 Chevy Z71 O2 sensor simulator
    By stelmadl in forum GM Trucks
    Last Post: 10-04-2005, 05:00 PM
