    Mar 2010
    my house
    2002 camaro
    more oxygen sensor help
    ..........got my new denso oxygen sensor......dunno what happened, but the wires are about 6 to 8 inches short......im guessing i can cut the wires from my old one and butt connect them onto the new one ?......correct me if im wrong.... thanx
    Senior Member 98maro's Avatar
    Feb 2010
    north bay california
    00 camaro ss M6 #6695
    I was told that you cBt cut the cable on the oxygen sensors
    Bad idea. Buy some extensions
    02 tahoe Z71 blacked out
    98 z28 red m6 sold
    07 zx6r ninja flat/black sold
    08 zx6r ninja sold
    do you have headers and what is the part number of the denso's?
    Mar 2010
    my house
    2002 camaro
    i do NOT have headers....and the part # is 234-4087.......it said pre- cat right
    how long is the harness on that? Going by memory but the stock harness itself is only about 6-8" long.....been a while since I've messed with stock sensors but that's going by memory. When you compare it to the front sensor harness it comes up that much short? Like I say, been a while since I've seen stock sensors.
    Mar 2010
    my house
    2002 camaro
    im gonna say the stock sensor is about a foot long ( the wire part) and the new sensor is approx. 4 inches too short.......could i have gotten the wrong sensor I.E. the passenger side instead of the drivers side?
    denso lists that as the pre-cat right which would be the passenger side. Whatever you do try not to splice wires.....people have created some real headaches for themselves doing that. You can either send it back for the correct sensor or buy a premade extension.
    Mar 2010
    my house
    2002 camaro
    ok , thanks Orion....ill just buy the pre cat left....and change them both out.
    Junior Member ws66sw's Avatar
    gulf coast, texas
    00 formula ws6
    old thread, but may be useful
    2000 ws6 formula failed smog, codes indicated that the 02 sensors were bad. I went with denso
    part # 234-4025 there are 3 of these
    " 234-4087 " " 1
    4087......12.2" wires
    4025......16.54" "
    went all thru the internet, conflicting info on whether upstream, downstream, right, left, etc.
    common sense says that if they are the same part numbers, what difference does it make
    4025... location exhaust pipes
    4087... after catalytic converter
    conflicting info... 4025 says upstream pre-cat left on some sites, downstream on others
    " " 4087 says upstream, pre-cat right on some sites, upstream on others
    my point is what difference does it make if 3 of them have the same part number and same length, while the other one has a longer length. just take them out and compare them, put the longer one where the longer one is on the car, put the other three where they are on the car.
  1. oxygen sensor simulator help
    By Ghawk996 in forum External Engine
    Last Post: 11-16-2012, 03:32 AM
  2. Question: Walker oxygen sensor (has anyone used these)
    By allbaugh_04 in forum General Help
    Last Post: 11-12-2009, 07:23 PM
  3. Oxygen Sensor
    By NJ2002WS.6 in forum General Help
    Last Post: 09-04-2008, 04:09 PM
  4. Oxygen Sensor turned red
    By RV7LS1 in forum General Help
    Last Post: 06-26-2008, 02:06 PM
  5. o2 solenoid oxygen sensor
    By feras in forum External Engine
    Last Post: 04-19-2007, 02:50 AM
