    Aug 2006
    South Florida
    2000 Z28 Camaro
    Oxygen Sensor 2000 Z28
    Can you swap the rear sensors to the front on the same bank? Are they a universal application as far as position and bank?
    Thanks!
    Santee, CA
    On the 1999-2002 LS1's, I believe you can.
    The sensors share the same interface connector housings (according to my 2002 GM Camaro Service Manual).
    Pin/Wire colors for HO2S Bank 1 Sensor 1:
    Pin A = Tan/White, Pin B = Purple/White, Pin C = Black, Pin D = Pink
    Pin/Wire colors for HO2S Bank 1 Sensor 2:
    Pin/Wire colors for HO2S Bank 2 Sensor 1:
    Pin A = Tan, Pin B = Purple, Pin C = Black, Pin D = Pink
    Pin/Wire colors for HO2S Bank 2 Sensor 2:
    The colors above are for the harness wiring to the O2 sensor interface connector.
    According to the Autozone website, all four O2 sensors carry the same Bosch part number (13444), which means you can swap bank to bank as well.
    Vance Chula
    1996 Camaro Z28 SS #1688
    2010 Camaro 2LT RS
    http://www.cardomain.com/id/vchula
    Bragg NC
    Met. Sunset Orange
    01 SS
    Lol i had the same question months ago, so i tried it.
    Yes they are all interchangeable, the only diff is the wire length.
    J
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    ^^+1
    Member fast droptop's Avatar
    Charlotte, NC
    sunset orange
    2001 SS VERT
    Anyone need any? Hell I have like 3 or so sets in my garage.
    2001 SOM SS Vert 1 of 37 verts with a 6 speed. Kook LT's with cats, fast 90mm ported intake, Nick Williams 90mm TB, AFR 205's and so on. Tuning/installs done by Williams Performance.
    Aug 2006
    South Florida
    2000 Z28 Camaro
    i bought a new one for 75 bucks.
    Thanks everyone!
    I found that the shop that gutted my cats somehow damaged my bank1 sensor1 o2 sensor. grrrr i hate cleaning up mechanics messes! Its time to get a garage lol
    LS1 or bust b.lee's Avatar
    Aug 2006
    SE, Michigan
    Blue
    00 Z28 6Spd / 03 Z71 LT
    if you get the cats gutted or take them off the rear O2 sensors will always throw on the service engine soon light.
    they are supposed to be reading 'converted' exhuast, but they arent, and if you replace them, they will still throw that some code.
    you need to get the PCM re-programmed, or get the O2 similators from somekind of racing company.
    Junior Member R&L'scamaro's Avatar
    South Carolina
    1998 Z28 Camaro
    I need a set o2 sensors if you still have them. Just let me know how much.
  1. more oxygen sensor help
    By 2002 in forum General Help
    Last Post: 08-21-2016, 06:17 PM
  2. Question: Walker oxygen sensor (has anyone used these)
    By allbaugh_04 in forum General Help
    Last Post: 11-12-2009, 07:23 PM
  3. Oxygen Sensor
    By NJ2002WS.6 in forum General Help
    Last Post: 09-04-2008, 04:09 PM
  4. Oxygen Sensor turned red
    By RV7LS1 in forum General Help
    Last Post: 06-26-2008, 02:06 PM
  5. o2 solenoid oxygen sensor
    By feras in forum External Engine
    Last Post: 04-19-2007, 02:50 AM
