Thread: Headlight issue?? help!
12-05-2011, 09:49 AM #1
My driver side headlight is making an awful grinding noise once the lights are turned off. I'm not sure what the problem is because the headlight goes up and down without a problem. The noise is like delayed a couple of seconds. It's almost like the motor will not disengage. So I had to pull the fuse and leave the driver side light up. Is there a relay or something that tells the motor to stop? or is the motor bad?
12-05-2011, 01:19 PM #2Junior Member
- Jul 2007
- Plano/Lubbock TX, Miami FL
Vendetta Red- 2000 Trans Am
Your gear is stripped.
12-05-2011, 02:28 PM #3Senior Member
- Mar 2010
- St Pete, FL
Bat mobile black- 2000 Trans am WS6 M6
Your gear is probably missing a tooth on the side its using (it only uses 50% of the gear). The gear inside is plastic and they tend to chip over time. You can do like i did a month ago and be cheap and lazy and take the gear out and flip it around. You might get lucky and it work for another 10 years but if youre like me you will end up having to buy a metal gear to fix it, because after i flipped it around another tooth broke. A new motor is about 250 bucks. A metal gear is about 45. I bought the Gear kit from Hawks 3rd Gen for 45 and im going to install it tomorrow.
12-06-2011, 01:03 PM #4
I had that same problem when I bought mine. It's a really easy fix. Get the metal gears already mentioned. Install it and let the epoxy cure overnight. Re-install the motor in the morning. Might take some minor tweaking with the swing arm but you should be good to go after that. Make sure to clamp the motor while the epoxy is drying so it gets a good seal and won't pop off while the motor is operating.
12-06-2011, 11:10 PM #5Be who you are and say what you feel 'cause people who mind don't matter, and people who matter don't mind.'
-Nowhereman
12-07-2011, 09:45 AM #6
Headlight issue
By FutureWS6 in forum Firebird / WS6Replies: 17Last Post: 01-20-2011, 02:18 PM -
Help: key fob and headlight issue.....
By qwk93ta in forum General HelpReplies: 3Last Post: 08-18-2010, 04:03 AM -
Yet another headlight issue
By JC70SS in forum Firebird / WS6Replies: 7Last Post: 06-19-2009, 12:16 PM -
Headlight Issue
By Red99TA in forum Firebird / WS6Replies: 5Last Post: 01-23-2009, 12:58 AM -
Headlight Issue
By Ws6 Love in forum Firebird / WS6Replies: 9Last Post: 07-31-2007, 08:40 PM
