Results 1 to 18 of 18
Thread: Headlight issue
12-30-2010, 09:46 PM #1
Headlight issue
I had posted b4 about a sound one of my headlights was making when i turned them on 2 where they raise up. and now it finally wont go up all the way like the other side does. I was told to just turn over the gear but....uh..idk what im looking for. and when its humid it makes a squeaking noise. but only when its humid and goes away after 10-15 mins but its driving me insane. i know its a pully im pretty sure on my passenger side but which one...
12-31-2010, 09:40 AM #2
1. Description- open your hood then look just behind the headlight that is making the noises you will see a round looking knob that looks like a allen wrench will fit in it. That knob is your manual raise and lower knob. Then if you take the black shroud off of the headlight that is held on by i think 4 screw and look underneath the headlight you will see a electric motor that is what raises your headlights when you turn them on and is where your gear is. Conected to the motor is a metal bar that has a hinge in the middle of it that is connected to the motor with a 10mm nut i think.
2. Gear Turning- Raise you headlights with the switch if you can then remove black shroud, then remove the nut and pull the hinged bar from the motor. After removing the bar from the motor use the manual raise knob to to turn the gear inside 180 degrees. You can tell how much the gear has rotated by watching the stud that the bar was bolted to until it reaches the complete opossite direction it was facing. After turning it to the described about rebolt the bar back to the motor and flip the switch for the lights to see if the noise has stopped.
12-31-2010, 03:45 PM #3
01-01-2011, 08:18 AM #4
- Dec 2005
- Tampa, FL
Pewter- '00 TransAm WS/6
The link that Y2KPewterSS gave tells the story.
If you pull out the headlight assembly, there is an electric motor that runs the lights up and down. Inside it, there's a plastic gear driven by a metal worm gear. Over the operational life of the headlights, the gear wears down.
Generally, the gear only touches the worm gear on half of it, so you may be able to disconnect it, rotate it 180 degrees, and reconnect it. That may save you for a while.
The GM solution is to replace the motor. That's expensive. The way most of us go is to go on eBay and find someone selling a replacement gear. I think there was someone on here selling them too. I've bought 3 from a guy on eBay who has both brass and aluminum gears. He switched to aluminum because of the cost of brass. Don't replace it with another plastic gear, or it will fail again. Look for the kit that also has a little metal T-bar. That will bolt in when you reassemble it, and give it a bit of extra strength.
The replacement isn't very hard. Just follow the directions. The first time around, it'll probably take you a couple hours and a bit of cursing about the placement of the bolts.
I've replaced both sides on my '00 TransAm WS/6, and one on the '98 TransAm I had.
As the old one fails worse, your headlight will end up not moving on it's own, and it'll make a god awful sound when it's going up and down (or trying to), and since it won't ever be in the right position, it'll do the same when you lock and unlock your doors with the key fob.
As for the squeeking, have fun finding it.It could be the belts or anything that moves. Mine was doing it too, so I finally got around to changing both belts. The serpentine is a piece of cake if you've done it before. You have to crawl under neath to change the A/C belt. A friend with a Camaro SS had a squeaking when her water pump was starting to fail. It was a few months between the noise starting and the pump failing.
To find the location of the squeak, one trick is to stand in front of the car idling. Cover one ear, and move your hand around slowly between you and the engine. It'll get quieter when your hand is between your ear and the source of the noise.
01-01-2011, 05:49 PM #5
01-01-2011, 07:52 PM #6
01-12-2011, 11:16 AM #7
Question
Does the battery need to be disconnected before replacing head light bulbs?
Thanks.
01-17-2011, 01:00 PM #8
Having trouble getting the bar off after i got the nut off. Am i supposed to do anything b4 that?
01-17-2011, 06:14 PM #9
01-18-2011, 06:29 PM #10
i kinda gotta force it right? cause i tried again today with no luck, but im mainly just scared to break anything
01-19-2011, 08:08 AM #11
Spray it down with some wd40 or something. Like damian~ said turn the allen to take the bind off of it. Pry with a wide blade screwdriver behind the bar... it'll come off.
01-19-2011, 11:12 AM #12
01-19-2011, 02:29 PM #13
Mine quit going up a couple of months ago so I did the rotate trick and it only worked a couple days .... as I tried to remember if I'd already rotated it before. Anyhow I opened it up to replace the gear and the fricken thing already had a brass gear in it.... so not only had I rotated it twice but I replaced the gear ...LOL. That bothered me to see that gear. I went ahead and replaced it and it's been fine for a week. I can't imagine that that plastic worm gear could wear out a brass gear....???????
01-19-2011, 03:22 PM #14
01-19-2011, 07:36 PM #15
I thought you needed to disconnect it, but I had a problem with my harness after I changed them, and had to play with it when it was running with the lights on, and it doesn't close when you disconnect the harness, so, no, you don't have to pull the battery. Better off, but good info to know. And pulling the linkage off, I got my nail bar out, and put some muscle into it. Grunt,pop,done.
01-19-2011, 07:46 PM #16
01-20-2011, 06:02 AM #17
No ... but if memory serves me right - you should remove the headlight cover.
01-20-2011, 02:18 PM #18
- Nov 2008
- Camarillo CA
Silver- 1996 Silver Trans Am M6
Let me tell you that I had the same issue with my WS6. However after replacing the gears, and putting the units back together I noticed the arm on my driver side motor was not completly resting against the metal tab witch stops the arm. Well I didnt think much of it at the time. it seamed to work fine. Well after time the arm bent the tab back and the arm would spin around and the headlight would go crazy. So I ripped it out and tried to bend the tab back, and it snaped off! So long story short. the dealer had to rip the whole front end off to replace it. Witch ended up costing me $1500 bucks in labor and parts. The point im trying to get is be carful when messin with these things. what seems like an easy fix could end up costing you a lot. might want to concider paying the 400 at the dealer. Good luck.
Help: key fob and headlight issue.....
By qwk93ta in forum General HelpReplies: 3Last Post: 08-18-2010, 04:03 AM -
Yet another headlight issue
By JC70SS in forum Firebird / WS6Replies: 7Last Post: 06-19-2009, 12:16 PM -
Headlight Issue
By WICKED LS1 in forum Firebird / WS6Replies: 4Last Post: 04-23-2009, 08:02 AM -
Headlight Issue
By Red99TA in forum Firebird / WS6Replies: 5Last Post: 01-23-2009, 12:58 AM -
Headlight Issue
By Ws6 Love in forum Firebird / WS6Replies: 9Last Post: 07-31-2007, 08:40 PM
