Results 1 to 13 of 13
Thread: Help 02 ws6 wont start?
06-17-2011, 02:51 PM #1
Today i drove my t/a to the store, everything was fine no unusual sounds or behaviors. I turn off the car, come back turn the key and nothing. All the dash lights turn on there is power everywhere it wont fire. It doesnt even try to crank. I replaced the starter, didnt do anything. Tried jump starting it and pop starting it, nothing. There is power through the whole ignition system to the starter all the fuses are good. The only thing different is the security light in the gauges is now flashing. I tried the process to relearn it to the chip in the key and no good. Any idea's on whats wrong. im stumped?
06-17-2011, 02:55 PM #2
mods are just lid, longtubes, and cat delete magna flow cat back.
also when i started it to get to the store, the starter didnt sound weak if fired right up.
Its almost like trying to start the car without pressing the clutch. we tested the switch behind the clutch which is also good.
06-17-2011, 06:19 PM #3
VATS? Do you have another ignition key? Or maybe clean the contacts on the chip and give it a try.
06-17-2011, 07:05 PM #4
Just gonna throw this out there. The linkage in the ignition is all plastic, could have slipped a cog. You probably would have noticed it by now, though. There is also a very small wire hooked to the ignition cylinder. Maybe that got pinched. Prob isnt your problem, just thrownig it out there.
06-18-2011, 01:13 PM #5
replaced the ignition cylinder did the trick, i can breath now
06-18-2011, 01:24 PM #6Senior Member
- Nov 2006
- Indianapolis
Did the cylinder have the two small wires to it? I can't remember if they do, I think they do. If so, those are your VATS wires and one was probably broken.
06-18-2011, 01:36 PM #7
mine did the exact same thing i just disconnected the battery for 10 sec and she fired right up
99 Pontiac Trans Am Silver: Custom K&N Intake, 85mm BBK SSI Intake, 85 PP Throttle Body, Pacesetter long tube headers, TSP off road y-pipe, TSP Rumbler catback, Torque Thrust II sitting on Nitto 555 all around, 20% tint, and the free mods
1997 Cadillac Deville~32v northstar v8
06-18-2011, 05:25 PM #8
06-18-2011, 05:36 PM #9
I had an 89 iroc that the same thing happened and it was the wire running to the ignition cylinder for the security. Replaced cylinder and all was good.
06-18-2011, 05:37 PM #10
I just can't believe that my out of the ball park thought was on.
06-20-2011, 10:12 AM #11
Happened to my grand am back in the day as well. Actually using a new key worked for a little bit until the whole thing went crazy. Your security system was engaged. A new key probably would have worked temporarily/for a while. The ignition cylinder is a perma fix, so congrats on that, and sometimes you can get behind everything and mess with the wires. (yellow one?)
06-20-2011, 01:38 PM #12
sorry about the lack of info, i didnt fix it my dad took care of it while i was in work.
06-20-2011, 01:40 PM #13Spaz is My Mentor
what did he do?
Help: car wont start and now gauges wont work!
By AB'sLs1 in forum General HelpReplies: 52Last Post: 04-20-2013, 08:54 PM -
Z71 wont start
By duranws6 in forum General HelpReplies: 4Last Post: 01-09-2013, 07:49 PM -
LT1 wont start
By Bad Co. in forum General HelpReplies: 8Last Post: 11-18-2010, 07:23 AM -
LT1 wont start
By Bad Co. in forum LT1Replies: 0Last Post: 11-16-2010, 05:32 PM -
car wont start
By redss2000 in forum General HelpReplies: 12Last Post: 06-20-2008, 01:06 PM
