06-02-2011, 04:21 AM #1
Possible Vacuum Leak with BBK SSI manifold...
I have been tracking down a vacuum for a couple of weeks. I bought the car it had the BBK SSI and 80mm TB on it. I found a few glaring issues I fixed and am trying not to pull the intake off.
I removed the cover plate on the egr hole (which I don't have, '02) and found the oring that should seal the plate to the intake does not fit right (see photo).
Do you think that this could be a potential vacuum leak source? The groove is ~ 0.170 deep and the oring is 0.130 thick.
If anyone has a BBK SSI and no egr, could you pop the plate off and see if the oring makes a good seal?
Thanks.
Jon
06-02-2011, 04:28 AM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
It could very well be the source of your vacuum leak. To confirm, put the cover plate back on, spray a little starting fluid around the area while the car is running. If the idle raises, you've found the leak.
06-02-2011, 02:47 PM #3
Fill that gap/ring with some RTV sealant and bolt it back on.
Let it dry for a day and all should be well.
06-03-2011, 06:36 AM #4
06-03-2011, 09:45 AM #5
06-05-2011, 04:45 PM #6Electrical Engineer
- Jul 2009
- North of the Motorcity
If this didn't solve your leak issue, it could be a PVC leak.
Vacuum leak
By 00hawk109 in forum General HelpReplies: 6Last Post: 07-17-2011, 09:39 AM -
Vacuum Leak from EGR
By jpn8801 in forum General HelpReplies: 0Last Post: 04-21-2011, 05:59 PM -
Vacuum leak
By edrvsqz1980 in forum Firebird / WS6Replies: 3Last Post: 08-14-2010, 07:16 AM -
Vacuum leak
By blackbird0230 in forum External EngineReplies: 3Last Post: 04-25-2010, 08:39 PM -
Help: Vacuum leak (I think)
By clow76 in forum General HelpReplies: 7Last Post: 08-12-2009, 03:21 PM
