Results 1 to 10 of 10
Thread: 18x10.5 rim on front?
04-26-2011, 05:56 PM #1
hey guys i was wondering if it is possible to run an 18x10.5 rim on the front of my camaro. with maybe a 275/35/18 tire. anyone with expierence please chime in
04-26-2011, 06:29 PM #2Senior Member
- Feb 2010
- Greenwood, IN
Light Pewter Metallic- 2001 Camaro SS
10.5s will fit. your biggest problem is going to be with the tires. a 275 is going to be too small for a 10.5. the smallest you can go is a 285 but the tire is going to be extremely stretched in order to fit. I have 10" wheels in the front and I wish they were 9.5s so that my 275s fit without the slight stretching.
04-26-2011, 06:38 PM #3BANGIN GEARS>STAB N STEER
- Nov 2009
- Jacksonville FL
TRIPLE BLACK- 2000 CAMARO SS M6 #2100
What is the reason for doing this? Find a great deal on some wheels or something? IMO stretched tires are hideous and pointless. I wouldn’t go much more than 9.5 in the front personally.
04-27-2011, 08:52 AM #4
what about with a 295 tire on the front, will it fit?
04-27-2011, 09:59 AM #5
04-27-2011, 10:48 AM #6BANGIN GEARS>STAB N STEER
- Nov 2009
- Jacksonville FL
^^^this
It will most likely be ok in a straight line but once you turn the wheel it will probably rub pretty bad on the wheel wells, especially if you’re lowered then it will be a nightmare. I don’t recommend this at al unless you modify your car for it. I honestly don’t see the point in going more than a 275 up front but if this is just something you really feel is necessary then do what you gotta do. I mean really almost anything can be done with the supporting modifications, I have seen guys run 315s in all 4 corners before. Good luck with it man and keep us posted with what you do.
04-27-2011, 11:22 AM #7
04-27-2011, 11:57 AM #8Senior Member
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
thats too much rim for the front... 17x9.5 with 275 tire is just perfect..
i ahd 285s before with 9.5 fits fine but is to wide i would never go wider than 275s 9.5..00 ss blk m6 " STOCK" strano springs, slp bilstein shocks, adj LCA, adj panhard bar, relocation brackets, 2 point SFCs welded,OEM zo6 rims black, magnaflow exhaust, CME exhaust,E/cutout, slp grille, custom front plate mount, HIDs, whistler mod, side moldings delete, slp air lid, ported and polished TB, strut tower brace, 3.73s gears, and some other parts to list!
02 tahoe Z71 blacked out
98 z28 red m6 sold
07 zx6r ninja flat/black sold
08 zx6r ninja sold
04-27-2011, 01:56 PM #9
this is very true, i didnt think about that. i think i will prob just stick with the 275 on a 9.5 rim to be safe and prob a 295 or 305 out back on a 10.5 rim. prob a little hammering in the back will be needed but im not worried about that as long as its not too much. thanks for the replies guys
04-27-2011, 10:35 PM #10
18X10 in the front?
By EnemyAce in forum Wheels and TiresReplies: 8Last Post: 04-02-2010, 11:49 AM -
18x10.5 up front
By SScamaro400 in forum Wheels and TiresReplies: 6Last Post: 02-08-2009, 02:00 PM -
18x10.5 zo6's ?
By "B4C" in forum Wheels and TiresReplies: 7Last Post: 11-03-2008, 09:42 AM -
C6 18x10.5 with 295/35/18 ok?
By schrysler in forum Wheels and TiresReplies: 15Last Post: 01-22-2008, 12:20 AM -
Will 18x10.5's fit on a fbody?
By grandkodiak in forum LT1Replies: 10Last Post: 02-11-2006, 04:25 PM
