Results 1 to 11 of 11
    - = LR = - grandkodiak's Avatar
    x
    Will 18x10.5's fit on a fbody?
    Will 18x10.5 black z06 style rims fit on my 96 trans am front and rear?
    Clinton, MS
    1997 Camaro Z28
    depends on the offset for the rears...........if they are 50mm they will fit
    I have 17x11's on mine and all i had to do was cut half of the bump stop off.
    x
    The ones I'm looking at come in 54, 56 and 58 offset?
    Clinton, MS
    1997 Camaro Z28
    get 56 for the front and 50 for the rear
    that is the GS offset
    where are you buying them?
    Oct 2001
    Colorado
    95 Z28
    I wouldnt put 10.5 inch wide wheels on the front in a street car. They'll fit in the rear, but as was said above, will likely require some massaging, perhaps in the inner fender and bumpstop, and in some cases rolling the fender lip (on the inside).
    These cars follow every groove in the road with 9.5 inch wheels and 275/40 series tires up front... I dont even want to drive one that has wider tires up front (for street duty)
    Clinton, MS
    1997 Camaro Z28
    Quote Originally Posted by 5.0THIS
    Some guys actually run 17x11's on all four corners.......however I wouldnt recommend it. The front will need a lot of modifying for it to be able to turn properly. run 18x10.5 in the back but only 9.5 up front.
    You will be happy with that
    Commerce Ga
    Black, Blue
    07 TBSS, 07 GSXR1000
    I agree 100% with you on that.
    Oct 2001
    Colorado
    95 Z28
    Quote Originally Posted by Scottslt1z28
    That's why I kept mentioning for a street car. I've seen it done on autocross/road race cars, but honestly never on a street driven setup.
    camaro_ss_97_
    Guest
    i have the black zo6 rims 17x9.5 in the front and 18x10.5 in the rear both with 54 mm offset. i have a buddy that has the 18x10.5 all around and they work great
    x
    Thanks! I'll have to do that then... but how does it look with 17s in the front and 18s in the back? I have stock 16's on now, and was planning originally 17's, but then i saw 18. is there a performance drawback with going with 18 inchers from weight?
    Oct 2001
    Colorado
    95 Z28
    Quote Originally Posted by grandkodiak
    lol.. I knew you were just waiting for the opinion that's what you wanted to hear.
  1. 18x10.5 Tires?
    By TransAmX2 in forum Wheels and Tires
    Last Post: 04-30-2011, 10:08 AM
  2. 18X10 in the front?
    By EnemyAce in forum Wheels and Tires
    Last Post: 04-02-2010, 11:49 AM
  3. 18x10.5 up front
    By SScamaro400 in forum Wheels and Tires
    Last Post: 02-08-2009, 02:00 PM
  4. 18x10.5 zo6's ?
    By "B4C" in forum Wheels and Tires
    Last Post: 11-03-2008, 09:42 AM
  5. C6 18x10.5 with 295/35/18 ok?
    By schrysler in forum Wheels and Tires
    Last Post: 01-22-2008, 12:20 AM
