Thread: 18X10 in the front?
03-09-2010, 01:56 PM #1Junior Member
- Jul 2008
- Canada
Bright Red- 2002 WS6
18X10 in the front?
I'm looking to buy a set of ROH RT's for my WS6. I found a good deal on 4 18X10's but am wondering of that size will fit in the front. I know an 18X10 will work well in the back but most people seem to go with 18X9's for the front. Will this work?
Also, the bolt patter listed is 5 x 4.75 or 5 x 120.65. Compatible?
Dave
03-09-2010, 02:02 PM #2
I'm running 18"x10.5" on the front with a +56mm offset no rubbing at all.
What's the offset on the rims?
03-09-2010, 03:15 PM #3Junior Member
- Jul 2008
- Canada
The offset is listed as 5. Is that 50mm you think?
03-09-2010, 07:06 PM #4Just me
- Nov 2006
- Broken Arrow, OK
I know of people that run 11s in the front. I run 18x10 in the front with zero issues. Probably more room in the front for wider wheels than the back.
03-09-2010, 08:15 PM #5
04-01-2010, 12:53 PM #6
04-01-2010, 01:43 PM #7
I'm running 295/35 in the rear.
I think 305/45's are too tall of a tire.
04-01-2010, 11:15 PM #8
I've never seen anyone a 45 on a 18" wheel with that width. You bottom out a little to hard those won't hit just the lip you'd probably damage the 1/4 panels. I know people running widths like that but in a 35 series on 17" wheels.
I've seen one car running my rims in18x10 all around. I went for the 8.5 front because I like the staggered look better but should have no issues as long as the offset is correct.
1998 Trans Am 85k miles.
02 Trailblazer -Sold
09 Ram 1500 CC - Sold
09 Cobalt SS/TC - Sold
04-02-2010, 11:49 AM #9
That could be 5cm, so yes 50mm.
You should have not problem mounting a 18 x 10 +50 offset up front.
Contact Group A Wheels just to make sure.
http://www.groupawheels.com/Index.aspx
PM Sent.Last edited by Blue28; 04-02-2010 at 12:28 PM.
Question: 18x10.5 rim on front?
By 02fbody35th in forum Wheels and TiresReplies: 9Last Post: 04-27-2011, 10:35 PM -
18x10.5 up front
By SScamaro400 in forum Wheels and TiresReplies: 6Last Post: 02-08-2009, 02:00 PM -
18x10.5 zo6's ?
By "B4C" in forum Wheels and TiresReplies: 7Last Post: 11-03-2008, 09:42 AM -
C6 18x10.5 with 295/35/18 ok?
By schrysler in forum Wheels and TiresReplies: 15Last Post: 01-22-2008, 12:20 AM -
Will 18x10.5's fit on a fbody?
By grandkodiak in forum LT1Replies: 10Last Post: 02-11-2006, 04:25 PM
