    Hammond, LA
    18x10.5 up front
    I was just curious if a 18x10.5 rim with a 295/35 tire will fit up front on a 4th gen camaro. If so what offset should I run? If not then I'll just stick with the 18x9.5" rims.
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    I have them and they tuck in inside the fender... and I have 315/30-18 on them.
    You can click the link in my signature or check here: http://www.ls1.com/forums/showpost.p...96&postcount=6
    Also, the C6 wheels are +56mm offset... a 1/2" spacer is needed to have what I get on stockish brakes setup.
    Eugenio_SS
    Hammond, LA
    would a 58mm offset be better or worse? And would I still need the spacer?
    Thanks
    Jun 2002
    Montreal, CANADA
    triple-black
    Ideally, for no spacer, you'd want in the range +40mm to +48mm offset, +44mm being the closest to ideal in the front... of course that is providing you have stockish braking system.
    In my case, because I have a Porsche braking system, that pushes everything by 1/2" outwards, where the wheel will sit, making the C6 or C6-Z06 wheels a perfect choice for me without any spacers... but I doubt that is your case.
    remember the higher the offset, the more it tucks in; the lower, the more it sticks out.
    Hammond, LA
    Great exactly what I needed to know
    Also where did you get your spacers?
    Jun 2002
    Montreal, CANADA
    triple-black
    www.skulte.com makes great ones.
    I use a 1/4" spacer in the rear and that's it... the Porsche kit takes care of moving my wheel a 1/2" outwards.
    Jun 2002
    Montreal, CANADA
    triple-black
    Quote Originally Posted by Jhonny View Post
    I have 305/25 on my camaro
    I would assume that the tires you talking about are 19s ?
  1. Question: 18x10.5 rim on front?
    By 02fbody35th in forum Wheels and Tires
    Last Post: 04-27-2011, 10:35 PM
  2. 18X10 in the front?
    By EnemyAce in forum Wheels and Tires
    Last Post: 04-02-2010, 11:49 AM
  3. 18x10.5 zo6's ?
    By "B4C" in forum Wheels and Tires
    Last Post: 11-03-2008, 09:42 AM
  4. C6 18x10.5 with 295/35/18 ok?
    By schrysler in forum Wheels and Tires
    Last Post: 01-22-2008, 12:20 AM
  5. Will 18x10.5's fit on a fbody?
    By grandkodiak in forum LT1
    Last Post: 02-11-2006, 04:25 PM
