Results 1 to 20 of 20
    Senior Member
    Toronto
    SOM
    2002 SS
    No start wtf!! Turn the key no starter !
    First time it's ever happened to my ss.. Turn the key all power on battery fine and I hear the fuel pump pressurize just no starter or any clicking at all. Ideas?
    Member jsmith564`'s Avatar
    Apr 2009
    covington ga
    yellow
    2004 gto
    does it turn over? pump put out about 55-60psi? coils have power?
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    The only thing you can do is jack up the car and lightly tap on it with a hammer and screwdriver. If the car turns over afterward, your starter's toast.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    This could be related to your other thread. It may be possible your fuel pump took a shit. Also, you mentioned you just swapped out the fuel filter. Did you kink a line? Leaking any fuel?
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Just b/c your fuel pump is making noise, that doesn't mean it's pressurizing.
    I'd check the pressure at the rails incase of what 35th mentioned.
    Senior Member
    Toronto
    SOM
    2002 SS
    Honestly I hope it's related to my other thread. The starter isn't even clicking though. If it was the pump it would turn and not fire but it's not turning. Line wasn't kinked for sure the underbelly on this California car is in great shape all the lines loosened really easy etc.
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    Quote Originally Posted by 5abivt View Post
    Have you checked fuses/relays?
    No security light, right?
    Senior Member
    texas
    2000 formula
    Vats!!!!
    security light on? If so it's vats. If not it could be stuck solenoid on the starter or a starter relay.
    Senior Member
    Toronto
    SOM
    2002 SS
    No securitylight. I just got home sadly I couldn't take the ss out butbi got home now and gave it a try and it fired right up. A few minutes ago I had to run out again and no start again. The first time I did unlock the door manually as well but not sure if that has anything to do with anything.
    I cleaned the key.I have a spare which I'll try when I get home. I noticed the little chip has very very slight movement in the key. Normal?
    When I turn the key I hear a faint tick which sounds like it's coming from the fuse/relays drivers side engine compartment.
    Senior Member
    Toronto
    SOM
    2002 SS
    Went out for a drive came back and tried again no luck.. im screwed if I cant get to work tomorrow. Anyone got any ideas? I swapped the relays for the starter with the ignition although I realize one wouldnt work without the other :/ still no go. I found my spare ignition key and still no luck so its probably not the chip being bad unless its inside the ignition on the column.
    Im about to with this car
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    no and sometimes that will cause a problem. The chip is not supposed to move, but alot of them do as they age.
    Madison, WI
    2001 Silverado Z71
    Senior Member
    Toronto
    SOM
    2002 SS
    I will def try that tomorrow if I cant get it started. Going to check all the cables/grounds to and from the starter now.
    Senior Member
    Toronto
    SOM
    2002 SS
    Ok guys you should read this !! If it ever happens to you it might help. I found this thread on LS1tech from googling no-start ls1 camaro:
    http://www.ls1tech.com/forums/genera...ont-start.html
    The youtube video the op put up is EXACTLY the same problem I am having and I watched the video and wondered what the hell he was doing holding on to the iginition in the run position for so long for. Turns out it started.. here's his Video:
    [ame]http://www.youtube.com/watch?v=dJcuBm0UFMk&feature=player_embedded[/ame]
    SO, i went outside and decided to try it for myself.. and sure enough IT STARTED !! Just like the video 30 seconds later or so of holding the key in the run position it fired right up. I drove it around and got it hot and came home and it started like 10x in a row. I dont think problem is solved but I am guessing like the op in the thread I linked my starter is on the way out. I will price them out tomorrow and grab one soon if this occurs just once more.
    thanks everyone for the input !
    Orlando, FL
    Mean Black
    one way to find out if it is the starter for sure is to check if you have 12v at the starter solenoid wire. If you can get someone to the turn and hold the key in the start position the voltmeter should show 12v or the test light will light up. If this happens your starter solenoid is most likely bad. If you don't get a reading then you have issues with power to the starter solenoid.
    Senior Member
    Toronto
    SOM
    2002 SS
    Great to know I'll look into checking that. Where is the solenoid? Right on the starter?
    After watching the video clip, I had a similar problem like that with my 96' Firebird. I thought it was VATS, starter, relays, everything. Turn out it was the tumbler that the key goes into. There are 2 pressure mounts inside of it that touches the chip and closes the circuit for the VATS to work. I had to take it apart and re-solder the connections. After that no problems ever again. I'm not saying this is your exact problem, just something that I know that has happen to me and a fix.
    yes
    Oct 2010
    n/a
    n/a
    This used to happen in my old car. No problem with starter it was the ignition system mainly reading the incorrect key code.
  1. Help: Car does not start, does not turn over
    By transAMchubby in forum General Help
    Last Post: 09-02-2014, 06:59 PM
  2. Oh %*{#*= car won't start... Starter???
    By 5abivt in forum General Help
    Last Post: 06-13-2011, 05:02 PM
  3. Sometimes Security Light, No Start - Starter?
    By clovenhooves in forum Firebird / WS6
    Last Post: 10-29-2009, 01:18 PM
  4. Car Wont Start, When Jumoped Gauges turn off + On?
    By Patsy57 in forum Stereo and Electronics
    Last Post: 04-11-2008, 11:26 AM
  5. turn off oil change indicator after start up.
    By zdude in forum General Help
    Last Post: 02-16-2008, 06:49 PM
