Results 1 to 20 of 22
01-15-2006, 12:41 PM #1Junior Member
- arizona
black- 2000 z28 conv.
turn off oil change indicator after start up.
How do u turn of the oil change indicator once the car starts?
It stays on for a few seconds.
When I bought the car it did not come with manual. Also looking for a manual. I do change oil every 3000 miles. Oil is at right level.
My car is 2000 Z28 black conv. with a 5.7 liter auto trans.
01-15-2006, 01:02 PM #2Senior Member
- Jul 2005
- Jacksonville, FL
Turn the key to RUN with engine off, push the TRIP/OIL RESET button on the dash for 12 seconds, the light will start to flash to confirm it's reset. You can also turn the key to RUN with engine off and depress the gas pedal 3 or 4 times and it'll reset without resetting your trip mileage.
01-15-2006, 01:09 PM #3Senior Member
- Jul 2005
- Jacksonville, FL
Forgot, you can get a manual from a dealer, www.helminc.com or a pdf for free at http://shbox.com/pdf/manuals.html
01-16-2006, 05:22 PM #4
the trip odo reset button won't do anything for the oilchange light reset on a Camaro. You need to do the gas pedal reset-turn key to on and press down and release the gas pedal within 5 seconds start to finish three times.The oil life calculator is a fairly accurate method for determining when to change oil IMHO-I use it .
01-16-2006, 08:18 PM #5Junior Member
- arizona
Thanks for your help. The indicator is off. Thanks
01-16-2006, 08:37 PM #6SUPREME member-oderator
- Nov 2005
- Lost in Texas
Custom Slate Blue- 99 B4C
if you need a manual drop me your email
01-16-2006, 09:05 PM #7Holding down the trip resets it on my camaro...
Originally Posted by 02z28ls1
01-17-2006, 09:40 AM #8Senior Member
- Jul 2005
- Jacksonville, FL
Worked for me too. For some reason mine has only illuminated once since I've had the car (23K). Only thing I can think of is I've replaced the battery a couple times, or reflashing the PCM during tuning might reset it???
01-17-2006, 09:09 PM #9Member
- Burlington, NC
Black- 2000 Camaro SS
Holding down the trip/reset button like 2001NBMZ28 said, at oil change time, works for me.
JEB
01-17-2006, 09:28 PM #10heyyyy..I said it too
Originally Posted by JEB
01-17-2006, 10:48 PM #11
OK-when I'm wrong I'll admit it-You apparently can do it both ways on a Camaro-the first tip off being the fact that it says trip/oil reset next to the button ('duh' at myself). At some point in early 1998 w/my first Camaro I reset it using the gas pedal method and never looked at it any other way. My only defense here is that I work on hundreds of different cars every year and don't always remember every thing about my own car. My Bad-let's move on (insert derisive laughter from audience here).
01-17-2006, 10:51 PM #12SUPREME member-oderator
- Nov 2005
- Lost in Texas
mine says trip/oil and I HAD to do it with the petal, I couldn't get the button to work even though it says trip/oil
01-17-2006, 10:56 PM #13
I have never tried the trip/oil reset button on mine for that purpose-how would you get it to just reset the oil life system and not the trip function?I'm looking in the owner's manual (factory service manual has nothing I can find on it)and it doesn't go into detail-this is getting more interesting..........
Anyone?
01-17-2006, 11:14 PM #14weird...maybe your car doesn't like you
Originally Posted by z_driver1
01-18-2006, 09:17 AM #15SUPREME member-oderator
- Nov 2005
- Lost in Texas
It was a chicks car. . . . . . . . . . . my car>
Originally Posted by SeVeReDiStOrTiOn
<me
damn hoe cars
01-18-2006, 09:58 AM #16
I never reset the light. I like it illuminationg making me think I'm in some kinda high tech space craft.
01-18-2006, 11:15 AM #17
I'm sorry but I find that hard to relate to
01-18-2006, 08:04 PM #18Heh....I get the same feeling but with my SES light
Originally Posted by Danger731
01-19-2006, 08:38 AM #19Senior Member
- Jul 2005
- Jacksonville, FL
The pedal method is supposed to reset it without disturbing the trip mileage, it's not in my owners manual though, only the trip/oil reset method is - in mine it's in the index under "H" for "How to reset...light."
01-19-2006, 11:49 AM #20Member
- maine
black- 2000 ws6
Normally the light on mine is always on when its oil change time. If i push the button it only makes it so its on for 5 seconds after restart. I have to use the pedal to reset it.
Dunno if ive tried holding it 12 seconds though... so maybe holding it that long completely resets it
Help: Car does not start, does not turn over
By transAMchubby in forum General HelpReplies: 23Last Post: 09-02-2014, 06:59 PM -
Malfunction indicator light
By supersmooth in forum General HelpReplies: 3Last Post: 06-21-2011, 02:24 PM -
No start wtf!! Turn the key no starter !
By 5abivt in forum General HelpReplies: 19Last Post: 04-18-2011, 10:05 AM -
Question: Oil life indicator?
By TheJudge05 in forum GTOReplies: 8Last Post: 03-23-2010, 07:15 AM -
Car Wont Start, When Jumoped Gauges turn off + On?
By Patsy57 in forum Stereo and ElectronicsReplies: 3Last Post: 04-11-2008, 11:26 AM
