    Member TheJudge05's Avatar
    May 2008
    MA
    Yellow
    2005 GTO M6 - One of 498
    Oil life indicator?
    Does anyone know if the oil life indicator system actually measures the quality of the oil as opposed to a simple mileage counting system? Basically I'm asking, if I change the oil and reset the system, will it simply alarm me once I have reached a certain number of miles, lets say 6500, vs. a system that truly measures the quality of the oil (viscosity, clarity) and will tell me to change the oil once it senses that the oil is actually dirty?
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by TheJudge05 View Post
    No it does'nt test/measure the oil for quality.. Most of them also go by engine revolutions not mileage.. The sensor/ecm does'nt know the difference between dirty/clean and the light will come on until it is manually reset.. Your ecm is simply not that complex..
    May 2008
    MA
    Yellow
    The ECM can easily handle an oil quality sensor, it is much more complex then you might imagine. The question is whether or not there really is a sensor or does the system just base the oil change indicator on # of RPMs or time, etc.
    Pittsburgh
    2008 Hummer H3
    Trust me what triggers your light is NOT that complex.. You asked a question I gave the answer..
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    This might help some. There is no oil sensor that detects its condition in your case. It is calulated from many different factors.
    http://assets.cobaltnitra.com/teams/...145efa6b30.pdf
    Build in progress...
    Pittsburgh
    2008 Hummer H3
    All rendered useless the moment your're driving and don't stop the very second the light comes on to change the oil and reset the light.. If you wait only 1 mile more after changing the oil to reset the light then it is no longer caliburated.. = BS, useless system and hence no complexity.. Change the oil, reset the indicator, call it a day..
    May 2008
    MA
    Yellow
    Thumbs up
    Thanks Hi-po, the document nicely explains the system and it makes sense. There is a complex algorithm in the ECm that accounts for mileage, rpms, temp, time, humidity. I'm getting close to needing an oil change so I was wondering about the system and when it might go off. I drive mainly hwy so that is probably why I am going to be north of 7000 miles between changes.
    Florida
    1999 TA WS.6
    I cant understand what your trying to say here, but I guess I can understand the last sentence
    May 2008
    MA
    Yellow
    Agreed, really just a bunch of nonsense... Some advanced oil monitoring systems actually check the quality of the oil by running it thru a true oil sensor, ours do not. But then again our cars weren't $55k BMWs, Lexus, or Caddys...
    The system in our cars has validity because it is basing the change recommendation on real world conditions that are tallied in the ECM, fair enough.
    Most people change their oil much too often anyway; with the advancements in oil technology (additives etc) and filtration technology, one can easily go 10k plus on an oil change if they are using synthetics, which all of us should be.
  1. Malfunction indicator light
    By supersmooth in forum General Help
    Last Post: 06-21-2011, 02:24 PM
  2. Question: Is there a lamp for gear indicator?
    By Thewilldog in forum General Help
    Last Post: 08-08-2010, 05:56 PM
  3. Help: Gauges flash, and all indicator lights
    By Blue_01_Z28 in forum General Help
    Last Post: 03-09-2010, 08:54 AM
  4. need Camaro A4 shift indicator...
    By Bad30th in forum Western Members
    Last Post: 09-13-2008, 06:14 PM
  5. BCM ,not VATS indicator problem
    By sic2001 in forum General Help
    Last Post: 03-03-2006, 06:24 PM
