Results 1 to 20 of 24
    Member transAMchubby's Avatar
    St. Louis, MO
    '99 Trans Am
    Car does not start, does not turn over
    I'm about out of options. And about finished with this car.
    '99 Trans Am, M6
    When turning the key, the engine does not turn over, starter does not click or tick or make any noise what so ever like it is trying to start.
    I drove my gf and I on a date about a month ago. Came out, and the car would not start. Would not turn over, or even click. She has AAA so the AAA truck shows up, he tests the battery and says it is just fine.
    Security light is not on, not flashing. It does light up when turning the key, along with every other light on the dash, then they go off just like a normal startup sequence. Just to rule it out, I turn the key, then sit and wait at least 3 minutes, then turn key off, then try to start car. Nothing changes.
    After trying a few things including knocking on the starter with a hammer handle, then a screw driver handle, while turning the key, no change.
    I switched the starter relay with all 3 fan relays, no change.
    We ended up pushing the car, popping the clutch, and I drove straight home, parked in the garage.
    I took the starter off, took it to Advance Auto Parts: hooked it up to the tester and it spun immediately. The guy there is familiar with f-bodies (has a camaro and is active on a local racing forum) and said the starter sounds normal. Put the starter back on, no change. Still won't start.
    I bypassed the clutch switch today, still no change.
    Took the battery to get tested and charged at O'Reilley's. The guy there said it is good, needed a charge, but the battery is still good. Re-installed, nothing. Still not even a click from the starter.
    Sanded the connectors and brass bolts to the battery, nice and shiny (same as the connectors at the starter.) Still nothing.
    All the fuses look good, and even swapped the IGN and Starter fuses with others to make sure. Nothing changes.
    I have an OHM-meter (ameter?) on its way over this evening that I will use to check the key and do the VATS bypass just to rule that out, but again, the security light is not on, is not flashing.
    I have an INNOVA 3030 OBD2 scanner which will not pick up dealer codes, and I hooked it up: no non-dealer codes. Dealer wants $135 just to plug in their computer and check for codes (which takes all of 2 minutes to do) but I refuse to support that kind of BS from a dealership (a one hour tech charge for 2 minutes of work). Is there any other kind of shop that might carry the same type of scanner?
    Now my garage drywall has a hole in it the size of my hand, and I cant drive my car without parking on hills. I do have a daily driver, but I need to get this trans am running again.
    Any other ideas? At this point I'm desperate.
    Thank you.
    St. Louis, MO
    '99 Trans Am
    ohm-meter set to 20k ohm setting: reading is 1.85
    This corresponds to GM key number 7 which has a resistor of 1.87. I'm going to try finding resistors and bypassing the VATS. Will post results.
    St. Louis, MO
    '99 Trans Am
    so, I bypassed the VATS today. it Didn't help anything. I had a buddy help who has done his before, and after trying to start the car (nothing happened) I removed the resistor, tried to start it again, and the security light started flashing. so I plugged in the VATS again and the security light didnt flash. ruling that out.
    i'm going to go ahead and get a starter, replace that, and if it fixes it then i'm set. if not, i'll take it back off and return it.
    thanks so far for the help. if its not the starter at that point, then i'm going to get ahold of a wiring diagram and start diagnosing other components on the same circuit as the starter. i'll have to get ahold of a multimeter at that point.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    OK. Is the battery the original Delco? I ask as they are known to leak and the negative terminal has a tendency to separate from the battery casing causing a no-start or the negative terminal would just simply fall out. The VATS doesn't seem to be the culprit nor is the starter. Is it hard to turn the key in the lock cylinder in the column? You could have a faulty BCM as well. Keep us posted.
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Sounds like it could be the ignition cylinder. Remember it's the second part to alot of things your checked off already.
    I had to replace it on mine and I had very similar conditions that you do.
    East of Cleveland, Ohio
    99 WS.6 - Modified
    I would check to see if you are getting any voltage to the starter relay when turning the key. If not, I'd suspect the ignition cylinder as stated. If you have voltage, trace from the relay out to see where it's being lost.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Try the ignition switch. That would be my first guess. Then I would check the body mount computer. After that I would try the battery. It may have internal issues and not make contact when a load is put on it. Good luck, let us know how you make out.
    St. Louis, MO
    '99 Trans Am
    thanks for all the help and ideas so far...i'll see what i can do before the weekend. just so busy with work and class.
    St. Louis, MO
    '99 Trans Am
    well, still searching. when I bypassed the VATS there was this click (or tick, or pop, or light bang) that happened when releasing from turning the key, and only made one "click." It came from kind of within the dash, but was easier to hear from under the hood up by the clutch fluid reservoir. My buddy and I figure it was related to the relay "kicking." In addition to taking his working starter relay out of his t/a to try, we determined the relay is again not the issue.
    I put a new starter on tonight (just wired it, didnt blot it in) and a new starter changed nothing. i had this suspicion, but figured i would at least give it a try.
    i'm going to start searching for 2 things: a wire issue; and someone in the St. Louis area that might be able to replace the ignition cylinder (or a walkthrough)...
    again, thanks for the help so far. i'll keep this thread posted and will definitely let you all know what the culprit is if i ever find it.
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    North Jersey
    2004 GTO M6
    Let us know if you need anything else.
    Member ls1ws6ben's Avatar
    Apr 2010
    west monroe, la
    ok so i had an issue like this in my TA a few months ago.. drove it from my work place to the store.. came back out and it wouldnt start, no gauges worked, nothing.. called a friend of mine that is a mechanic.. it was a blown fuse for the gauges.. i think it was a 10 amp fuse.. he told me to put a 15 amp in there.. went to lowes next door and got some fuses and put in a 15 amp fuse and it fired right up.. i would have never guessed a gauge fuse being blown would stop a car from starting.. sorry i didnt see this post sooner, but try that.. its really going to suck that you have gone through all of this and it is that blown fuse.. i was lucky and called my mechanic right away.. hope this is all thats wrong.. its always the smallest things we over look!
    St. Louis, MO
    '99 Trans Am
    i got some results...I took the car to an LS-anything genius, CBI just outside St. Louis, MO.
    Turns out the ground to the starter relay was bad. now it's fixed and I'm picking it up this weekend.
    big thanks to CBI! and thanks to all the suggestions and help in this thread!
    Mar 2010
    Chicago
    Chameleon Green
    2000 Pontiac Firebird
    I am literally having the same issues as you, even went through the same damn processes of replacing all the parts. Batteries, VATS Bypass, starter, etc.. The last idea would have been the ignition cylinder lock, however with your results a buddy of mine will be printing out wiring diagrams and check that tomorrow afternoon. The only additional problem I have is that when I go to try and start the vehicle it blows out my 50 amp ignition fuse. I'll let you know the results tomorrow but if anyone has additional information on other possible ideas please help! I'm seriously fed up with this car and about to freaking dump it.
    Georgia
    red black
    98Z28
    If your blowing fuses, sounds like a dead short. Would be looking for a burnt or bad wire ...... Good luck.
    St. Louis, MO
    '99 Trans Am
    Quote Originally Posted by JerIcK View Post
    Best of luck jerick. I thought I'd just dump the car when I couldn't figure it out. Now I have a better understanding of the fbody and the term "electrical gremlins!"
    I've been daily driving mine for 2 months, did a burnout on an entrance ramp last night, and am glad to have it back. The only fall out I have now is the trip meter resets every time I shut off the car. Oh well.
    Keep pushing forward man
    '99 Trans Am Pewter M6
    St. Louis, MO
    Mods/upgrades: SLP lid-Longtubes-ORY-LM2 catback, drilled rotors&Hawk pads, MSD wires
    PITA: window motors+regulator, brass gear, DRL sockets X 7
    Soon: clutch, LS6 intake
    I know members here scream about SeaFoam. Many voted for Obama also.
    Mar 2010
    Chicago
    Chameleon Green
    Ended up fixing it after-all.
    Things I changed:
    1. New Battery
    2. Ignition Switch
    3. Ignition Relay
    4. Did the VATS bypass.
    Now shes running good as new and no more security light! haha... still thinking about getting rid of it, shes a headache and a half especially when I need her as a daily driver!
    St. Louis, MO
    '99 Trans Am
    Glad to hear you got it worked out!
    If it weren't for having another car to use as a daily driver I wouldn't be able to rely on my t/a and would have to ditch it. I just beat on it too much for it to be reliable.
    Junior Member arvizu9618's Avatar
    Apr 2009
    Phoenix AZ
    2002 Trans Am
    More info needed
    Quote Originally Posted by transAMchubby View Post
    The ground to the starter relay comes from the BCM when you turn your key to Start. I've got the same problem as you had and have already put a permanent ground on the starter relay, which bypasses the BCM. Still have random no start condition. What did they really do to fix your problem? Thx
    ASVIZU9618 you do realized your responding to a 3 year old reply/thread.
  1. No start wtf!! Turn the key no starter !
    By 5abivt in forum General Help
    Last Post: 04-18-2011, 10:05 AM
  2. Car Wont Start, When Jumoped Gauges turn off + On?
    By Patsy57 in forum Stereo and Electronics
    Last Post: 04-11-2008, 11:26 AM
  3. turn off oil change indicator after start up.
    By zdude in forum General Help
    Last Post: 02-16-2008, 06:49 PM
  4. Cold Start/Warm Start Problem
    By I'mLS1John in forum General Help
    Last Post: 02-23-2007, 07:11 PM
