Page 1 of 3 123 LastLast
Results 1 to 20 of 48
    Senior Member
    Toronto
    SOM
    2002 SS
    Oh %*{#*= car won't start... Starter???
    Had this happen just once about 3 months ago where my car didn't start. No turning of the starter. Now it's Friday morning and I'm supposed to get off work early and here I am late for work because it won't start. Starter probably dead?? I hear fuel pump, just a click from ignition when turned but no crank..
    Hard to swap? I tried hammering it to no avail.
    East of Cleveland, Ohio
    99 WS.6 - Modified
    Is your security light on? If so, it could be an issue with VATS. Otherwise, I would check for voltage at the starter, then the relay.
    99 WS.6 - Modified
    Here's a thread on disabling VATS if that turns out to be the issue - http://www.ls1.com/forums/showthread.php?p=1429555
    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    battery?
    Senior Member
    Toronto
    SOM
    2002 SS
    Thanks awesome threa that is! Can I find out the ohms by calling GM parts to punch the vin in etc?
    Is this a fix for flashing security light? My light isn't flashing. I tried my spare key and no go as well. I'd imagine if It is a vats issue it's in the ign lock itself?
    My first guess wouldn't be vats only because it happened 1x a dew months ago an hours later just fired and ran fine until this morning.
    Senior Member
    Toronto
    SOM
    2002 SS
    Battery is at good voltage as usual headlights bright as day etc still.
    Pittsburgh
    2008 Hummer H3
    If you're not even getting a, "click" then I'd guess starter relay, or corroded/blown ingition fuse.. Try moving the steering column up and down trying to start it. Could be an issue in the column or ignition switch. After that you're pretty much down to, VATS, solenoid, connections, and starter motor as possible causes...
    99 WS.6 - Modified
    Many people have intermittant issues with starting due to VATS. The security light doen't always come on either.I don't think a GM parts dealer would be able to tell you the ohms by the VIN.
    You could also check for voltage at the starter, while someone is turning the key. Obviously, be careful while doing so. If you have 12v, your starter is bad. If not, move to checking the starter relay.
    Pittsburgh
    2008 Hummer H3
    I also agree with this.
    But would start @ the relay personally, you need 12v there first..
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    An old timers trick is to have someone in the drivers seat turn the key to start the engine, while they are doing this, take a hammer and GENTLY start tapping the starter, if the vehice starts, then you know you have a bad bendix and need a new starter.
    SteveC
    99 WS.6 - Modified
    Either way works. For me, it's always the last thing I check that turns out to be bad....and I'd rather replace a relay than a starter
    Senior Member
    Toronto
    SOM
    2002 SS
    My biggest problem here is I've never used a little electrical 'tester' or whatever it's called . Time to bust it out of the package... I let the car sit for the last hour going down to try now and will look for the security light. I did try swapping the 2 relays to see if id get a click.
    Senior Member
    Toronto
    SOM
    2002 SS
    Ok my security light IS flashing the entire time !!! I guess I never really paid attention to it before but it is flashing indeed. Vats?
    Senior Member
    Toronto
    SOM
    2002 SS
    I have this.. Enlighten me guys what do I do with it lol .. I can do almost anything to my car but electrical stuff never my forte
    Senior Member
    Toronto
    SOM
    2002 SS
    I followeyhe instructions and got 9.53 settin the tester to 20k. What resistor do I need?
    Senior Member
    Toronto
    SOM
    2002 SS
    I followed the sticky and with key in ign I get nothing from putting the tester to the 2 white wires on the plug. This must be vats no?? Off to ride my bike to get some resistors!!
    Anyone tell me what resistor I need? I checked the spare keys and it's 9.49 it was 9.53 on my keys that I use. Setting on the meter was 20k
    99 WS.6 - Modified
    Quote Originally Posted by 5abivt View Post
    Get the resistor closest to the value of 9.5. I don't know what values the stores by you carry. If there is any question, get a few different (the closest higher and lower value) ones to try.
    Senior Member
    Toronto
    SOM
    2002 SS
    ok guys im more confused now. I re-read the sticky and I was supposed to check the resistance from the connectors under the dash with the key in the ignition and not in the 'run' position. I tried that and still nothing.. BUT..
    when I put the testers to the white/black stripe and white/purple stripe side of the connector.. I get a reading of -6.46 I get this with the key in OR out of the ignition. Still no reading of 9.49-9.53 on any wires though.
    Oct 2009
    pewter
    99 trans am
    isnt there a sticky about bypassing vats?
    Senior Member
    Toronto
    SOM
    2002 SS
    ya im following it but i have readings for my keys and at the wires its different. just trying to get as much info as possible really
  1. No start wtf!! Turn the key no starter !
    By 5abivt in forum General Help
    Last Post: 04-18-2011, 11:05 AM
  2. Sometimes Security Light, No Start - Starter?
    By clovenhooves in forum Firebird / WS6
    Last Post: 10-29-2009, 02:18 PM
  3. Starter
    By UKXK189 in forum External Engine
    Last Post: 01-24-2008, 10:56 AM
  4. Cold Start/Warm Start Problem
    By I'mLS1John in forum General Help
    Last Post: 02-23-2007, 08:11 PM
  5. Cold Start/Warm Start Problem
    By I'mLS1John in forum New Member Introductions
    Last Post: 02-22-2007, 06:26 PM
