Thread: Starter
    Pony Hater UKXK189's Avatar
    MN
    2001 Trans Am
    Starter
    So, the starter went out on my '01 T/A this morning. At least I am assuming it's the starter, when I try to turn it over there is no response at all. I tested the battery and it is fine. My problem is the shop I normally take my dd to said the starter will be $250, not including labor. That seems pretty steep for a starter, or am I just out of touch with price increases since I quit working on my last T/A in the early 90's?
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    the starter is like 175-200 bucks new. Don't pay a shop, it's only held on by two bolts and it's couple of wires, it's right on the bottom and easy to get to. You can swap it out in like 15 minutes. Seriously.
    MN
    2001 Trans Am
    Alright, thanks Frost.
    Very easy swap like Frost stated.
    Painted manta stripe
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    If it doesn't even CLICK, you may wanna try the cheap the easy route first; make sure the relay for the starter is good.
    Member Empatho's Avatar
    San Diego
    02 Z28
    try to do it yourself its not that hard
    2002 Z28 Auto (3.23 gears)
    Mods
    Lid, UD pulley, Shift Kit, 160 Thermo, Y-pipe, Panhard, TB bypass, Bellow, K&N, Strut Brace, Flowmaster, weight reduction.
    MN
    2001 Trans Am
    Turned out to be the VATS system. The resistor in my key went bad apparently, because it starts with the spare key, but not my normal key. So, guess I will be ordering a replacement key just in case my spare key goes bad.
  1. it is the starter right?
    By jondev in forum External Engine
    Last Post: 09-29-2008, 02:48 AM
  2. WTB....starter
    By 1tonzr2 in forum Parts Wanted / Trade
    Last Post: 03-11-2007, 07:02 PM
  3. Starter Going Bad.. HELP
    By LS1_WS6_TransAm in forum Firebird / WS6
    Last Post: 01-14-2007, 11:51 PM
  4. Bad Starter??
    By Wikid NaSSty in forum General Help
    Last Post: 09-25-2006, 09:59 PM
  5. Does this mean I need a new starter?
    By AKIRA in forum General Help
    Last Post: 08-12-2005, 08:37 AM
