Results 1 to 10 of 10
    Twin Falls, Idaho
    blue
    99 Z28 Camaro LS1
    Question help with turn signal
    My 99 Z28 turn signals when on flashes so fast it's like it's a solid light. All bulbs are good and fuses ok too! Does anyone have idea what's going one here?
    Tulsa,OK
    Quick Silver
    2002 Z06
    Might be a bad flasher.. They are cheap.. Just buy one and try it out.
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
    Junior Member BlackbirdRamAir's Avatar
    Dec 2009
    1999 Trans Am WS-6
    Alternator might be overcharging... had that happen with my 91 GTA
    Twin Falls, Idaho
    blue
    99 Z28 Camaro LS1
    K I got the flasher replaced and turn signal works properly now, thanks! But, I forgot to ask about my horn, it sounds only when I use my keyless remote but not at the wheel. I think it might be a relay but don't see it under dash. There's one under the hood, swaped it with another and nothing changes! Any ideas on this one?
    Tulsa,OK
    Quick Silver
    2002 Z06
    Since the horn works with the keyless entry all relays and power to it are probably fine..
    Its just the connector you are pushing on the steering wheel. I have never taken a 4th gen sterring wheel apart but my old 3rd gen just had some copper that touched and it could break real easy.
    Twin Falls, Idaho
    blue
    99 Z28 Camaro LS1
    K I'll try that tomorrow. Thanks!
    Member bryceslu's Avatar
    Chicago, IL
    00 NHRA Formula
    Quote Originally Posted by danmeksch View Post
    bad Flasher? i am having a very similar issue...blinkers go at mach 5. what do you mean by flasher?
    Twin Falls, Idaho
    blue
    99 Z28 Camaro LS1
    Pull off your panel under steering wheel and to the right of column there will be a clip holding a small round silver canister. This is your turn signal flasher. Note- it is not all the column but to the right of it! The part is under $4. Cheap fix!
    Chicago, IL
    00 NHRA Formula
    Is this the flasher relay?
    Twin Falls, Idaho
    blue
    99 Z28 Camaro LS1
    yes
  1. Question: turn signal keeps going out.
    By dav-02ws6-m6 in forum General Help
    Last Post: 02-02-2012, 02:19 AM
  2. Turn signal?
    By GrapeApeTA in forum General Help
    Last Post: 01-23-2011, 11:14 AM
  3. Question: turn signal
    By SSMOKEshow in forum Camaro / SS
    Last Post: 06-09-2009, 03:18 PM
  4. Turn Signal
    By Z28boy2000 in forum Stereo and Electronics
    Last Post: 03-30-2009, 11:36 AM
  5. Turn Signal PLEASE HELP
    By TA2FST4U in forum General Help
    Last Post: 06-01-2006, 07:35 PM
