Results 1 to 3 of 3
    Aug 2008
    LOS ANGELES
    trans will not go into gear after clutch install
    i have a 95 camaro z28 after my clutch install the trans will not go into gear when the car is on
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    If it does it when the car is off then you have air in the hydraulic system probably. What happens if you pump the clutch several times?
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by ajonesz28 View Post
    Did you fully bleed the clutch??
    Definitely sounds like the clutch isn't disengaging.
  1. 2002 Firebird Trans Am / Install 7.5-7.625-4:10 gear install
    By Buick455 in forum Automatic Transmission
    Last Post: 07-09-2015, 05:17 AM
  2. Getting out of gear with no clutch
    By Red99TA in forum Manual Transmission
    Last Post: 10-18-2009, 08:03 PM
  3. gear install
    By badblazeSS in forum Drivetrain
    Last Post: 09-18-2008, 09:16 PM
  4. clutch locks up 1st gear in traffic while riding clutch
    By Trixter in forum Manual Transmission
    Last Post: 04-22-2007, 09:01 AM
  5. Clutch or gear??
    By JLSain in forum Manual Transmission
    Last Post: 09-27-2005, 10:03 AM
